Author Topic: Varmilo VA109M noise  (Read 20089 times)
Offline Ali-Pacha
« on: Sun, 23 July 2017, 16:25:07 »
Edited : problem solved !  :thumb:
Ali
« Last Edit: Thu, 24 August 2017, 08:51:22 by Ali-Pacha »
Offline Username?
Re: Varmilo VA109M noise
« Reply #1 on: Sun, 23 July 2017, 17:15:43 »
Sounds like the metal plate causes resonance.
What happens if you apply pressure on the different places on the board? Can you reduce or stop the ringing?
Could it simply be a single screw or fastener missing which cause the plate to make contact with the insert?
/mynameis
