Author Topic: xwhatsit beamspring controller help  (Read 1725 times)
Offline xueyao
« on: Sun, 23 July 2017, 19:37:45 »
Hi guys! Recently bought a 3727 and an xwhatsit converter from orihalcon.
I've thoroughly cleaned the entire board including the pcb and the switches. Plugged in according to the manual but for some reason, column 9 which consists of the keys 5, T, G, B, is detected as permanently clicked no matter what voltage I set.
The only thing I havent tried is to swap the position of the switches but I doubt it'll help. The converter has been fully tested by orihalcon using an oscilloscope according to his post so I suspect it might be a fault with the pcb.
Does anyone know how to go about fixing this issue? Really wanna use this board. Thank you guys!
Offline y11971alex
  • Looking for Toronto meetup
Re: xwhatsit beamspring controller help
« Reply #1 on: Mon, 24 July 2017, 12:16:21 »
Check the edge connector for dust and the tightness of the backplate.
Offline xueyao
« Reply #2 on: Mon, 24 July 2017, 16:37:42 »
Wiped clean both, even wiped the pcb to be safe. I'm beginning to suspect there's really something wrong with the controller that orihalcon sent me but unfortunately he isn't replying.
