Author Topic: Holtites don't sit firm in TH pad.  (Read 1820 times)
Offline Eszett
« on: Sun, 23 July 2017, 20:49:08 »
Hi! I have original Holtites here (8134-HC-8P3), that don't sit firm in my 1.5 mm TH pads, how can that be? When I turn the PCB upside down they fall off. The datasheet recommends 1.61mm for the TH pad. :-[
Offline Tiramisuu
Re: Holtites don't sit firm in TH pad.
« Reply #1 on: Sun, 23 July 2017, 23:09:02 »
Have you tried solder?
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline Eszett
« Reply #2 on: Sun, 23 July 2017, 23:46:55 »
Hi Tiramisu. Nah, as I see from this Video they are pressed in with abit of force
But the guy in the video doesn't tell the diameter of his PCB's TH pads... Maybe I should shrink my TH pads from 1.5mm to 1.4mm to give the Holtites a firmer fit?
« Last Edit: Sun, 23 July 2017, 23:49:44 by Eszett »
