Author Topic: 30% ortholinear dvorak keyboard  (Read 11651 times)
Offline Nixon
« on: Mon, 24 July 2017, 12:54:21 »
After spending too much time browsing this subforum and loving the look of Mr Bishop's Pawn and the Gherkin, I decided to have a crack at a mini dvorak keyboard to use with my phone or Surface Pro.
Layout is here if you want to play around with it. link
Using the two function keys either side of the spacebar to switch layers, with the layout based on the dvorak Flesky android keyboard layout that I use on my phone. If I can get a trader on Aliexpress to send me one, I might add a flexpoint pointing stick mouse, and use the keys either side of the up arrow on the second function layer as right and left mouse click,
Fortunately I'm a Fablab technician so making the faceplate and case should be a breeze. Will probably prototype it out of plywood and acrylic but will probably make the final one out of CNC milled wood and either aluminium and copper.
Offline TalkingTree
    • My projects
Re: 30% ortholinear dvorak keyboard
« Reply #1 on: Mon, 24 July 2017, 13:38:39 »
This keyboard looks promising, I can't wait to see it done.
One thing I wanted to ask is why are you splitting symbols rather than shifting them? I mean, on an ANSI layout, dot and left angled bracket are on the same key, you just need to shift. Can't you just do the same instead of having so many unique keys?
Offline Nixon
« Reply #2 on: Mon, 24 July 2017, 13:46:42 »
There's only 33 keys, those 3 keyboards are the base level, Fn1  layer and Fn2 Layer. Should have labeled the diagram better. The final keyboard would look like this.
Offline TalkingTree
    • My projects
« Reply #3 on: Mon, 24 July 2017, 13:52:14 »
Yes, I get that, I'm talking of layers specifically, on Fn1 you have, for example, the number 1 and the exclamation mark on different keys while you can have the exclamation mark by shifting the number 1.
Offline Nixon
« Reply #4 on: Mon, 24 July 2017, 14:09:44 »
I'm trying to keep chording down to two keys. To have the exclamation on the same key as the number 1, I'd have to press FN1, Shift and the Control button at the same time. Using the layout with the exclamation mark on a third layer means I only have to press FN2 and K.
Offline TalkingTree
    • My projects
« Reply #5 on: Mon, 24 July 2017, 14:15:09 »
And you're achieving that with macros?
Offline Nixon
« Reply #6 on: Wed, 26 July 2017, 05:16:15 »
Knocked up a prototype top using the laser cutter at work just to see how it was to type on. I'm thinking I might make the two Fn Keys either side of the keyboard a tad wider to make hitting them with my thumb a bit easier. Will ruin the symmetry a bit but I can live with that.
Edit: Reuploaded a scaled down image.
« Last Edit: Wed, 26 July 2017, 05:38:50 by Nixon »
Offline tris0908
« Reply #7 on: Wed, 26 July 2017, 05:26:12 »
Super interested in this build. Even my smartphone thinks that this is going to be epic.
Sent from my SM-G935F using Tapatalk
Offline Nixon
« Reply #8 on: Wed, 26 July 2017, 05:40:00 »
Forgot to scale it down before uploading the image, fixed now.  :-[
Offline Nixon
« Reply #9 on: Wed, 26 July 2017, 09:28:07 »
Had a bit more spare time so quickly designed and laser cut a case. Needs a few tweaks but as a first prototype, it isn't too bad.
Offline TalkingTree
    • My projects
« Reply #10 on: Wed, 26 July 2017, 12:23:24 »
It's actually very pretty. Nice job.
Offline Nixon
« Reply #11 on: Fri, 28 July 2017, 03:26:33 »
Made a 3D model for the lower case yesterday and left it to 3D print over night. Just need to work out the best way to mount the Pro Micro in place. Doing a bit of CAD work for a guy who has access to a 4 axis CNC mill so might be able to get the final keyboard milled out of solid aluminium  :D
Offline fnurl
« Reply #12 on: Sat, 29 July 2017, 01:33:12 »
Wow, seeing threads like this make me really want to build something from scratch :) Have a few kit builds lined up as practice though :) Thanks for sharing!
Offline SBJ
  • Tactile pls
« Reply #13 on: Sat, 29 July 2017, 02:04:16 »
This is crazy small. :D
Well done m8 I thought 40% was ridiculously small but this is just on another level, haha.
Next up: 20%!
Offline Nixon
« Reply #14 on: Sat, 29 July 2017, 13:50:51 »
Next up: 20%!
There's the Bat Chording Keyboard that only has 7 keys: http://www.infogrip.com/bat-keyboard.html
Offline SBJ
  • Tactile pls
« Reply #15 on: Sat, 29 July 2017, 23:13:27 »
Next up: 20%!
There's the Bat Chording Keyboard that only has 7 keys: http://www.infogrip.com/bat-keyboard.html (Attachment Link)
That is just insane.
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #16 on: Sun, 30 July 2017, 21:55:48 »
Very cool, I am working on a similar project currently, what I am calling a 32%, since it has a few more keys than more common 30% boards, but still only 3 rows. You should call this a 35% for the extra row across the bottom and definitely keep us updated on progress!
Offline Nixon
« Reply #17 on: Mon, 31 July 2017, 06:17:32 »
Decided to 3D print and laser cut the prototype as I want to save the CNC favor for the mark 2, when I'm considering adding an Adafruit Feather Bluetooth board and a Flexpoint stickmouse to the keyboard for my ideal portable setup. Printing off the top half of the case today so I can wire it up while the bottom prints tomorrow. Attached a render of the current design below.
Offline Nixon
« Reply #18 on: Mon, 07 August 2017, 04:08:52 »
Finally got the case built and began wiring it.
175239-0
Even fits in my pocket, which is what I was aiming for.
175241-1
Also, please ignore the masking tape labeled keys, they're just there while I experiment with laser engraving them.
175243-2
Offline 0100010
  • Not Sure
« Reply #19 on: Sat, 12 August 2017, 18:58:08 »
Pocket fit is a nice touch.  I had put together a super micro ANSI layout long ago, but didn't think it was very practical - may have to rethink that.
Edit : Found it!
http://www.keyboard-layout-editor.com/#/layouts/e267bac69668809882c60436dbf84c03
« Last Edit: Sat, 12 August 2017, 19:05:06 by 0100010 »
« Reply #20 on: Sat, 12 August 2017, 20:52:41 »
Edit : Found it!
Really interesting concept, I like how you tried to fit full functionality in, would be oddly wide for how short it is front to back. I like seeing people's alt design ideas for 30+% boards
Offline Nixon
« Reply #21 on: Tue, 15 August 2017, 13:10:42 »
Got it finished on Friday ready and took it down to the MechanicalKeyboardUK meetup in Birmingham.
175948-0
The hardest part was flashing the firmware to the Pro Micro. Couldn't get QMK firmware flasher to work, nor AVRDude in an Ubuntu virtual machine. Ended up finding a generic arduino bootloader flasher in depths of the mechanicalkeyboard subreddit which did it perfectly.
Up next is harvesting the trackpoint from an old thinkpad keyboard for the second revision of my design.
