Author Topic: Newly retooled Matias switches  (Read 4961 times)
Offline pixelpusher
« on: Mon, 24 July 2017, 16:35:04 »
Remember a while back when Matias shared that reworked linear switch with a new housing that was supposed to have less wobble?
174119-0
Anyone have the scoop on what's become of them?
Offline drevyek
Re: Newly retooled Matias switches
« Reply #1 on: Tue, 25 July 2017, 02:57:07 »
Edgar is too busy making lasered PBT caps.
Offline pixelpusher
« Reply #2 on: Tue, 25 July 2017, 07:51:40 »
Ooh snap!
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #3 on: Tue, 25 July 2017, 08:39:18 »
Perhaps, just perhaps, they were busy stocking switches for Keyboardio.  ;D
Offline Blazestorm
« Reply #4 on: Tue, 25 July 2017, 15:10:27 »
They were out of stock on Matias.ca since maybe April or May? (possibly earlier) but they popped up recently: https://matias.store/collections/keycaps-and-switches-1/products/matias-quiet-click-switch-box-of-200
I ordered 400 and they already shipped. Guess I'll find out if they're really different or not =)
Offline pixelpusher
« Reply #5 on: Tue, 25 July 2017, 16:29:28 »
definitely let us know  :thumb:
Offline Blazestorm
« Reply #6 on: Mon, 31 July 2017, 23:55:31 »
I can say with decent confidence that they are noticeably less wobbly than the last batch (or whatever is installed on my VA68, I didn't build it).
They still wobble, but it's definitely closer to what you would be used to w/ MX switches. I'm not super picky about wobble (never sticker or swap housings because of it), but the old MQC batch was a bit too wobbly.
I could take them apart to w/ some pics, but it's looking good. Now I have to shave all these SP Alps stems down, so I can fit them onto these stems (still super tight/impossible without modding).
Offline pixelpusher
« Reply #7 on: Tue, 01 August 2017, 00:37:57 »
Good to hear it.  Yes, I plan to take a razor to my light cycle set when it gets here
Offline klennkellon
  • I like bottoming out
« Reply #8 on: Tue, 01 August 2017, 03:02:36 »
 Wobble doesn't bother me too much either, but it was definitely quite excessive before. I also hope that they fixed the wobble.
Offline dante
« Reply #9 on: Tue, 01 August 2017, 08:20:55 »
Wobble bothered me a lot on the linears.  A more appropriate name would not be "Quiet-Linear" but "Quiet-Rattle."  To think this switch was originally designed for stenographers in a court room - well I don't know if the judge would be too happy with that.
I suspect wobble would be less offensive on a non-dampened switch.
Offline pixelpusher
« Reply #10 on: Fri, 25 August 2017, 12:06:51 »
I picked up some spare matias click from a seller on reddit and they are very much improved.  Wobble is almost completely gone!
https://www.reddit.com/r/mechmarket/comments/6okrm9/uscahnew_switches_outemu_ice_rgb_tactile_click/
Offline ander
  • I type, therefore I am
« Reply #11 on: Sun, 27 August 2017, 04:30:42 »
You're saying Matias boards have Outemu switches now? So where does the Matias part still come in?
Offline pixelpusher
« Reply #12 on: Sun, 27 August 2017, 08:57:30 »
He's selling otemu, yes.  But he is also selling Matias switches :)
From the post:
For the alps fans - Matias Poly Carbonate shell alps variants
Matias Alps (white) - click $.31/ea
Matias Alps (grey) - tactile $.31/ea
Seriously considering swapping out all the switches in my v60 now
