Author Topic: 1996 Model M pinout (PCB)  (Read 5917 times)
Offline Half-Saint
« on: Sun, 07 March 2010, 06:35:51 »
Hi,
can someone help me figure out the pinout for that 4-pin connector? I threw away the cable and I'd like to attach a new one :)
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline ch_123
« Reply #1 on: Sun, 07 March 2010, 10:06:42 »
What part number? Is it a 42H?
but on the controller side you'll need to find someone that owns your model.
If it's a 42H, then it will be the same pinout as Unicomp's controllers. If it's a 52G or related, then it's the same as older Model Ms.
Offline Half-Saint
« Reply #2 on: Mon, 08 March 2010, 01:44:55 »
Well I don't have a pinout for the controller so CLK/DATA are fifty-fifty...
Here's what I gather:
- CLK/DATA
- DATA/CLK
- GND
- +5V
Yesterday I managed to desolder the connector and while trying to remove excess solder I managed to overheat two pads (for GND and +5) which ofcourse promptly deached from the PCB... luckily there are two more I can use, if I manage not to screw them up too...
Cheers
[SIGPIC][/SIGPIC]
Offline InSanCen
« Reply #3 on: Tue, 09 March 2010, 01:03:55 »
Trace the burnt pads back to the next component. Solder your wire there. Add glue to keep it in place when finished.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline Half-Saint
« Reply #4 on: Tue, 09 March 2010, 02:31:55 »
Will do! I just figured out I needed some better tools like:
- a proper wire stripper
- a "helping hands" soldering stand
- flux
- and finally some desoldering braid
After I get everything, I'm ready to fly!!! :)
[SIGPIC][/SIGPIC]
Offline ch_123
« Reply #5 on: Tue, 09 March 2010, 08:02:59 »
Again, what part number is it? What you need to do can vary between the keyboard you're working on.
Offline TexasFlood
« Reply #6 on: Tue, 09 March 2010, 08:39:29 »
Quote from: ch_123;162716
Would it be on the label?
Offline sandy55
« Reply #7 on: Tue, 09 March 2010, 09:27:32 »
Quote from: Half-Saint;162472
- CLK/DATA
- DATA/CLK
- GND
- +5V
Mine is Grenock, UK made 42H.
near control PCB
- DATA
- CLK
- GND
- +5V
bottom of a PCB
Through my experience I may say that cross wiring of DATA and CLK lines may not cause fatal damage to your KB or PC as far as you connect +5V and GND lines properly.
Offline kw71
« Reply #8 on: Tue, 09 March 2010, 11:32:47 »
HAY GUYZ.
The ground is easily identifiable.  It forms the 'ground plane' on the pcb.  Find continuity to a screw hole or the ground plane.  That is your ground.
+5 should have some caps between it and ground near the connector.
There are a couple polarized components - ie they have to be pointing the right way wrt +5 or ground - the big capacitor and the LEDs.
Once you find these two you can mix and match the data/clk without killing anything.  So if luck gets you the wrong way to begin with the first time you know the other way is right.
Offline Half-Saint
« Reply #9 on: Tue, 09 March 2010, 13:22:28 »
Would that be 1393669? :)
[SIGPIC][/SIGPIC]
Offline ch_123
« Reply #10 on: Tue, 09 March 2010, 13:36:04 »
Yeah, a 139- number would be it. But I'm not familar with that part number. What sort of cable does it have? Is it...
A) A detachable SDL cable.
B) A permanently attached coiled cable.
C) A permanently attached straight cable.
Offline TexasFlood
« Reply #11 on: Tue, 09 March 2010, 13:49:06 »
Quote from: ch_123;162790
Maybe like this one?
Offline ch_123
« Reply #12 on: Tue, 09 March 2010, 13:51:11 »
Not necessarily. Not all keyboards made from 96 onwards were 42Hs. There were still a number of SDL cable Model Ms made as late as 97 or 98. Mainly Industrial ones like the 1394950.
« Last Edit: Tue, 09 March 2010, 13:58:07 by ch_123 »
Offline TexasFlood
« Reply #13 on: Tue, 09 March 2010, 14:04:06 »
Quote from: ch_123;162792
Gotcha, I only posted the link since it's the only hit I got searching for a board with that controller.
Offline Half-Saint
« Reply #14 on: Tue, 09 March 2010, 14:26:07 »
Yes, like that one. It's a permanently attached straight cable.
[SIGPIC][/SIGPIC]
Offline Half-Saint
« Reply #15 on: Wed, 24 March 2010, 15:53:04 »
Well, I successfully destroyed the other two pads. I'm not sure whether it's my soldering skillz or the PCB quality is just ****e... anyhow, I'm done fixing this for now as I can't figure out where to solder the GND wire :)
[SIGPIC][/SIGPIC]
