Author Topic: [IC] Cherry MX Silent Black  (Read 40168 times)
Offline VicareyG
  • Vendor - Optic Boards
    • Optic Boards
« on: Wed, 26 July 2017, 07:23:27 »
The GB is now live
GB thread: https://geekhack.org/index.php?topic=90801.msg2466815#msg2466815 waiting on mod approval. until then here's direct link https://opticboards.com/group-buys/mx-silent-black
US Proxy: https://www.novelkeys.xyz/product/group-buy-cherry-mx-silent-black-switches/
Hello everyone!
I'm George. I run Optic Boards - www.opticboards.com
I have an IC here for Cherry MX Silent Black switches.
There is an MOQ of 48,000 switches! Which is incredibly high, to help achieve this I will only be allowing purchases of packs of 120, instead of the however many you want as long as it's more than 10 which I usually do. I will be getting the switches from Cherry's European distributor, so there will not be a re-seller in the middle.
The price is £26 for a pack of 120 or roughly £0.2166... per switch. ($33.94, so it is $0.282 per switch)
I will be pledging to purchase at least 40 packs of switches for myself leaving only 360 packs to be purchased by everyone else.
I would like to run this GB alongside a CONUS based proxy, so if anyone would like to jump in as a proxy let me know via DM  or email: george@opticboards.com.
Shipping prices. £3.50 UK, £5.50 EU, £7.50 everyone else.
Any questions let me know!
Update: Novelkeys has agreed to proxy over in the US! I'll update once he has worked out appropriate price to cover customs and shipping to him.
UPDATE: Novel Keys will be offering packs of 120 for $39 from within the US.
IC LINK HERE https://goo.gl/forms/0gHqwJawdSunpPV72
« Last Edit: Sat, 29 July 2017, 11:19:26 by VicareyG »
Offline rioc
Re: [IC] Cherry MX Silent Black
« Reply #1 on: Wed, 26 July 2017, 07:27:29 »
Nice, I'll join for a pack (maybe even two). Also from Europe here
Sent from my sofa using lazy-stuff...
Offline dgneo
  • Supervillain
« Reply #2 on: Wed, 26 July 2017, 07:31:00 »
Definitely in for a couple packs
Offline joey
« Reply #3 on: Wed, 26 July 2017, 07:36:27 »
Hmmmmmm I may be tempted at that price.
Offline TalkingTree
    • My projects
« Reply #4 on: Wed, 26 July 2017, 07:37:08 »
Do these switches have side pins?
Offline jihadu
« Reply #5 on: Wed, 26 July 2017, 07:39:54 »
Silent Blacks yum
Offline VicareyG
    • Optic Boards
« Reply #6 on: Wed, 26 July 2017, 07:42:19 »
I'm not sure what you mean by side pins. Could you elaborate?
Offline TalkingTree
    • My projects
« Reply #7 on: Wed, 26 July 2017, 07:44:29 »
I mean if they are PCB mounted.
Offline VicareyG
    • Optic Boards
« Reply #8 on: Wed, 26 July 2017, 07:57:30 »
Yes they are PCB mounted :)
Offline TalkingTree
    • My projects
« Reply #9 on: Wed, 26 July 2017, 07:58:48 »
Great. I'm in for two packs.
Offline rioc
« Reply #10 on: Wed, 26 July 2017, 08:01:22 »
aw yeah, perfect... I'm defo in for a tupac then :)
Offline afrokobe
« Reply #11 on: Wed, 26 July 2017, 08:49:48 »
Im down for six if you get a CONUS proxy.
Offline Petch
« Reply #12 on: Wed, 26 July 2017, 08:53:51 »
Being PCB mounted gives me a reason to get even more of them now
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #13 on: Wed, 26 July 2017, 09:02:43 »
If they are PCB mount, am I correct in assuming they will not have RGB housings?
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline VicareyG
    • Optic Boards
« Reply #14 on: Wed, 26 July 2017, 09:04:48 »
They are currently PCB mount black housing. I am waiting on a quote for RGB housing PCB mounted, if it is the same price the GB will be for the RGB variant.
Offline joey
« Reply #15 on: Wed, 26 July 2017, 09:08:20 »
If RGB = white housing, I'd probably prefer the non RGB :P
Offline Vigrith
« Reply #16 on: Wed, 26 July 2017, 09:08:42 »
Silent blacks within EU? Will join.
Offline VicareyG
    • Optic Boards
« Reply #17 on: Wed, 26 July 2017, 09:29:40 »
RGB refer to these http://cherry.de/cid/keymodules_CHERRY_MX_SILENT_RGB_BLACK.htm?
Offline kawasaki161
« Reply #18 on: Wed, 26 July 2017, 09:38:13 »
I'd be in for at least 2 packs (unless timing is really bad)  :thumb:
Offline VicareyG
    • Optic Boards
« Reply #19 on: Wed, 26 July 2017, 11:35:20 »
Talking to two US vendors. Fairly confident that there will be at least one US proxy for this GB.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #20 on: Wed, 26 July 2017, 11:36:41 »
I'm in for two if PCB and non RGB
« Reply #21 on: Wed, 26 July 2017, 11:41:46 »
In for one pack.  :thumb:
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #22 on: Wed, 26 July 2017, 12:05:18 »
Also in for a pack!
Offline Atredl
« Reply #23 on: Wed, 26 July 2017, 12:59:24 »
PCB mount, I'm in.
Offline Unforgivable
« Reply #24 on: Wed, 26 July 2017, 13:30:13 »
If they're PCB mount with Black housings, I'm in!
But please avoid RGB housings. You can't properly use LEDs with them, unless you place them inside the switch. They're normally used for RGB PCB's which aren't very common. (I think the only quality one available would be Zeal's RGB PCB - Those are PCB's with LED's on them).
So PCB mount with Black Housings, please!
« Last Edit: Wed, 26 July 2017, 13:31:55 by Unforgivable »
Offline Atredl
« Reply #25 on: Wed, 26 July 2017, 14:22:14 »
What makes them not suitable for regular LEDs?
Offline jihadu
« Reply #26 on: Wed, 26 July 2017, 14:29:17 »
They do not have the holes for the leds on the switch housing, forcing the user to disassemble the switch to install the LEDs. Normally cherry MX switches have  two holes in both the top and bottom housing allowing for a  easy Led install, but the RGB  variants have none.
Offline Atredl
« Reply #27 on: Wed, 26 July 2017, 14:34:07 »
Huh, I wonder why they got rid of the top holes. Seems like it would have been easier to use the same mold that they use to the black tops. Unless they were going for a structurally stronger top, I don't know why they need to make that change. Weird.
Offline jihadu
« Reply #28 on: Wed, 26 July 2017, 14:47:09 »
They made the change because the switches are meant to go on pcb with rgb leds that are independent from the switches
« Reply #29 on: Wed, 26 July 2017, 14:48:56 »
The RGB switches are marketed as having a 'lens' in that area to make the SMD below shine through 'better'.
Offline Atredl
« Reply #30 on: Wed, 26 July 2017, 14:57:03 »
Now I kinda want to get some of these tops and test the difference.
Offline jihadu
« Reply #31 on: Wed, 26 July 2017, 15:09:29 »
TIL
Offline VicareyG
    • Optic Boards
« Reply #32 on: Wed, 26 July 2017, 15:22:11 »
Offline jihadu
« Reply #33 on: Wed, 26 July 2017, 15:23:20 »
Nice! Not in the US but this will help MOQ
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #34 on: Wed, 26 July 2017, 15:28:17 »
GB cant start soon enough interested definitely to get atleast 2 packs. Thinking about getting even 4...
Offline VicareyG
    • Optic Boards
« Reply #35 on: Wed, 26 July 2017, 15:30:10 »
That's awesome! I'm shocked at the response tbh, 31,680 switches in the IC so far. I'm on holiday over the weekend so I'll keep everyone updated and hopefully a GB will start next week :D
Offline T0mb3ry
    • Flickr
« Reply #36 on: Wed, 26 July 2017, 15:34:22 »
You know thats the new jam. ;)
I hope these are solid black.
Offline VicareyG
    • Optic Boards
« Reply #37 on: Wed, 26 July 2017, 15:43:51 »
Once I have a quote for RGB housing I will post a poll, majority wins!
Offline Prelim
« Reply #38 on: Wed, 26 July 2017, 15:49:11 »
/in for it!
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline jihadu
« Reply #39 on: Wed, 26 July 2017, 15:50:15 »
/in for it!
True. Also in for Godspeed
Offline pixelpusher
« Reply #40 on: Wed, 26 July 2017, 15:51:24 »
I want to know how these feel compared to the silent reds that were in my filco from mechanicalkeyboards.com
I really dislike the feel of silent red.  It's like having a scratchy rubber dome keyboard :(  I cannot fathom why anyone would prefer that switch if they all feel the same way.  I suppose it's possible, but unlikely, that I got an "early" or "bad" batch that has since been improved upon?
« Last Edit: Wed, 26 July 2017, 15:53:09 by reececonrad »
Offline kawasaki161
« Reply #41 on: Wed, 26 July 2017, 15:51:44 »
I hope the majority knows that the RGB housings are brittle af  :thumb: .
Offline VicareyG
    • Optic Boards
« Reply #42 on: Wed, 26 July 2017, 16:03:20 »
Offline rioc
« Reply #43 on: Wed, 26 July 2017, 16:04:00 »
can someone tell cherry to jack up the price for the RGB housings?
we want solid black, non brittle, aesthetic AF housings  :p
Offline jihadu
« Reply #44 on: Wed, 26 July 2017, 16:05:49 »
Rioc telling it like it is
Offline T0mb3ry
    • Flickr
« Reply #45 on: Wed, 26 July 2017, 16:16:20 »
I cant speak for rgb. What i heard is that the solid black silent blacks are smooth and thats  the reason for the entire hype about it. Since i dont know about rgb i will most probably skip if these are going to be rgb. Its all about smoothnes and not rgb.
« Last Edit: Wed, 26 July 2017, 16:21:03 by T0mb3ry »
Offline Atredl
« Reply #46 on: Wed, 26 July 2017, 16:25:50 »
Is that $39 + shipping or $39 shipped (within US)?
Offline pixelpusher
« Reply #47 on: Wed, 26 July 2017, 16:27:55 »
Yes, but I also heard silent reds were smooth, and panda linears were smooth, but I bought them both, and both are certainly not smooth.  In fact, the silent reds are the scratchiest switches I've ever used.
Offline T0mb3ry
    • Flickr
« Reply #48 on: Wed, 26 July 2017, 16:35:53 »
Well seems like this time its different. Several people already confirmed that the silent blacks are smooth. Say people who actually received them: https://geekhack.org/index.php?topic=89588.150
Just read the comments. In case of pandas people who received these have emidietly noted that these are scratchy. Anyway i am already waiting for 200 silent black switches so i'll get my own opinion on it soon.
Offline Atredl
« Reply #49 on: Wed, 26 July 2017, 16:39:12 »
They most likely improved the switches since the batch you got. I've been using my silent blacks unlubed for some weeks now to get a feel for the "naked" switch before doing any mods. Even though I'll eventually add lube to get the best smoothness, I haven't felt the need to add lube yet. It's definitely smooth enough that I feel no need to do so until I swap out the springs. Take this from a guy who was more than happy to trade some wobble for smoothness.
