Author Topic: [GB] E6-V2 Custom 60% Keyboard - INVOICED  (Read 323554 times)
Offline PleaseBeMyFriend
  • formerly honsoo
  • reddit /u/PleaseBeMyFriend
Re: [GB] E6-V2 Custom 60% Keyboard - INVOICED
« Reply #1000 on: Tue, 24 July 2018, 15:53:41 »
Where would I go about finding the default layout?
EDIT: I'm looking at the QMK github for the e6v2 LE and see that there is a .c file that says caps lock LED fix...
Not the default layout, flashed a new layout on it on QMK Config with E6V2 LE. E6V2 and E6V2 OE wouldn't compile for some reason. On the default layout, I didn't have this issue, so it's definitely a FW issue.
For some reason, the caps lock light won't turn off...any ideas? I have the QMK version A1(?)
Is this the default layout? Have you flashed it yet?
e6v2 on its own is a directory so that won't compile.
OE seems to work just fine compiling, perhaps you had a wrong keycode. Regardless, please do not flash OE firmware for the LE board.
Could you try flashing the default layout again and seeing if the issue persists.
« Last Edit: Tue, 24 July 2018, 15:56:04 by PleaseBeMyFriend »
Offline lanyusea
« Reply #1001 on: Sat, 05 September 2020, 09:30:58 »
251058-0
251060-1
251062-2
just finished my assembling with Drop HP.
it has been kept in the box for almost three years, but still the best HHKB design I ever love!
hoping there will be the round 3 soon  :thumb:
HHKB Type-s / 4x KMAC Happy / 3x Duck Viper v1 / 2x Duck Viper v2 / 4x Duck Viper Duck TCV3 / Red Scarf 77 / 2x Infinity 60 / 2x ALF HHKB / LZ-CE / FJELL / Canoe / Canoe PC / Canoe FE / ARES Prototype / 2x Ares / LC-CLSh / TX60 / YODA2 / E6-V2 / E6-V2 FE / CAMP LC60 / 2x EM 7 / 4x Leaf 60 / UHK / Project F / Polaris / 4x Duck Viper v3 / TX60 v2 / Thermal / Matrix Falcon / TX60 v3 / 2x TMO50 / 2x Dolice / Dolphin 65 / Dolphin 60 / Plenty of keycaps
