Author Topic: [GB] E6-V2 Custom 60% Keyboard - INVOICED  (Read 338063 times)
Offline gaiden
Re: [GB] E6-V2 Custom 60% Keyboard - INVOICED
« Reply #900 on: Fri, 12 January 2018, 22:24:01 »
Guys when u solder board already
Plz post pic here I need you guys feedback
Appreciate it  ;)
First of all thank you Exclusive for coming through with overall smooth development and timely updates. Below are a few things I noticed which could be improved.
Quality is great. Feels very solid. My favorite HHKB so far! 8.5/10
That said IMHO there are a few things I like to point out maybe worth considering for better or worse:
(there are in no particular order, I'm just naming them as I go)
- The screw holes in the front bottom part could countersunk another 1-2mm so the entire screw would sit nice and flush when fully tight down
- Brass screws would have been better choice that goes better with the weight.
- I understand the screw under the name tag is different due to length but maybe it's something that could be avoid with minor redesign?
- The height of LED arcs on left and right side could raise another 5-6mm at least IMO because when I try to pick up the keyboard I would try to hold it on the sides and right now it's impossible
- Switch Plate having screw underside mount to the Top Plate before Top Plate having underside mount to the Bottom Plate would have been a better construction.
biggest hope is for higher LED arcs on the side that would be great.
my 2 cents  :)
Offline excluisve
  • Making & Thinking.
« Reply #901 on: Fri, 12 January 2018, 22:27:42 »
Appreciate it  ;)
my 2 cents  :)
I got it and will think twice ,thanks .
Offline excluisve
« Reply #902 on: Fri, 12 January 2018, 23:38:48 »
« Last Edit: Fri, 12 January 2018, 23:40:23 by excluisve »
Offline ptiede
« Reply #903 on: Fri, 12 January 2018, 23:46:45 »
Appreciate it  ;)
Here is my build! really good quality, I have some very minor marks on the bottom near the LED cutouts and a small scratch on the weight (pretty sure I can just polish it out) but other than that the board works great!
Here is an album of my build: https://imgur.com/gallery/4Vk75
Thanks exclusive!
Offline amnesia0287
  • Formerly Amnesia
« Reply #904 on: Sat, 13 January 2018, 01:42:43 »
Thanks  gaiden :thumb:
https://imgur.com/a/jJHmz#o6JYlf9
Hey, how'd he get his nameplate all nice and carved like that? My brass ones are like printed or something ;P
Offline Kafka
  • i like clean things
« Reply #905 on: Sat, 13 January 2018, 02:08:45 »
My E6-V2 nameplates are all engraved, my custom tags are printed tho
Offline excluisve
« Reply #906 on: Sat, 13 January 2018, 02:11:39 »
Standard E6v2 were engraving
Customized were print coz so much customized
Offline amnesia0287
  • Formerly Amnesia
« Reply #907 on: Sat, 13 January 2018, 02:38:06 »
I totally woulda ordered one if i had known that. I thought that one and the E-Team E6-V2 were standard. I totally woulda gotten 1-2 of those had I known they would look SOO much nicer. You should make stuff like that way more clear.
Offline excluisve
« Reply #908 on: Sat, 13 January 2018, 02:40:55 »
Yep ,next time I will all using printed it seems better than engraving.
White letter looks really good
Offline amnesia0287
  • Formerly Amnesia
« Reply #909 on: Sat, 13 January 2018, 02:50:40 »
Ehh, I kinda hate the printing. I woulda pay extra to get nice engraved brass ones with custom stuff. Printing on brass just looks cheap to me. Carved or smooth is fine, like, i would love to carve brass and then fill with enamel or something. But I HATE that I can feel the printing on the brass ones. Enough I'm not sure I'll ever use them. That's why I wish I had ordered the carved brass one like in that photo. It looks much more high end than any of the others.
Offline excluisve
« Reply #910 on: Sat, 13 January 2018, 02:57:35 »
Yea ,standard was engraving it more easy .
Customized was too much it impossible to engraving one by one  .not because the money  ,for factory is not necessarily
Offline Kafka
« Reply #911 on: Sat, 13 January 2018, 08:32:27 »
I prefer engraved much more, even if I can't customize it
Offline nonah
« Reply #912 on: Sat, 13 January 2018, 08:44:21 »
Agreed! Will never use my non-default ones because they look so much worse. Not a huge loss I planned on using the default ones anyway.
But it's probably something that should be made more clear if you plan on offering this for the next run!
Offline gaiden
« Reply #913 on: Sat, 13 January 2018, 08:57:06 »
TBH I ordered extras tabs/tags thinking they would be just blanks if no customization were put in but they all came in with E6-V2 on it. 1 printed in white and 1 engraved. I don't mind it but maybe in the future leave an option for blanks.
Sent from my SM-G935F using Tapatalk
Offline excluisve
« Reply #914 on: Sat, 13 January 2018, 09:12:37 »
Next run is the standard engraving
Customized was laser .
Offline gaiden
« Reply #915 on: Sat, 13 January 2018, 09:20:01 »
Add option for "blanks" too if you can.
Offline Mowo
  • Criminal Mastermind
« Reply #916 on: Sat, 13 January 2018, 17:21:27 »
Just finished my build, I think it turned out well. Only two real things I would change next time; Brass weight screws and the nameplate mounting.
Also, that green is looking good exclusive!
https://imgur.com/a/dpDsm
Offline DrWorm
« Reply #917 on: Sat, 13 January 2018, 22:44:02 »
I must have filled out the form oddly, because I managed to get mine with the default text, but printed. I like the look of the engraved more, too bad.
Offline excluisve
« Reply #918 on: Sat, 13 January 2018, 23:02:26 »
Fine ,about nameplate letter this things done .it will have a way solve next run
Offline Darknight00z
« Reply #919 on: Mon, 15 January 2018, 12:08:16 »
Does that mean there will be a R2?  :eek: :eek:
What about the E8-V1 TKL? I missed the GB  :'( :'(
Offline Quantastrophus
« Reply #920 on: Mon, 15 January 2018, 13:09:49 »
That brass plate is real :cool:. I wonder if there will be extra plates.
Offline TerryMathews
« Reply #921 on: Mon, 15 January 2018, 15:47:01 »
E2-V1 plz Exclusive
Offline excluisve
« Reply #922 on: Tue, 16 January 2018, 01:16:44 »
Some ppl still not get their E8 ,so it may not open until last orders get it
Offline excluisve
« Reply #923 on: Tue, 16 January 2018, 01:20:01 »
E2-V1 plz Exclusive
Okay. It will on schedule it may be longtime  :-[
Offline ocnis
« Reply #924 on: Tue, 16 January 2018, 04:19:19 »
Very happy with the final product, as the the board is pretty much flawless.
Thank you exclusive!
Album: https://flic.kr/s/aHskrzu9E2
Offline excluisve
« Reply #925 on: Tue, 16 January 2018, 22:05:43 »
Pretty nice. :thumb:
Offline excluisve
« Reply #926 on: Tue, 16 January 2018, 22:09:44 »
Take some pictures.
https://imgur.com/a/lf2xC
« Reply #927 on: Tue, 16 January 2018, 22:11:38 »
Offline excluisve
« Reply #928 on: Tue, 16 January 2018, 22:17:48 »
Offline amnesia0287
  • Formerly Amnesia
« Last Edit: Tue, 16 January 2018, 23:33:04 by Amnesia »
Offline dqu22
« Reply #931 on: Tue, 16 January 2018, 23:33:34 »
ignore, sorry
« Last Edit: Wed, 17 January 2018, 00:13:54 by dqu22 »
Offline afrokobe
« Reply #932 on: Wed, 17 January 2018, 09:08:20 »
Take some pictures.
dang, that looks insane.  already thinking of next colors  :thumb:
Offline excluisve
« Reply #933 on: Wed, 17 January 2018, 09:20:10 »
Take some pictures.
You may need rocket combo  :D
Offline maxf
« Reply #934 on: Wed, 17 January 2018, 12:35:27 »
I see the google form for this is still open.  Can these still be purchased?
Offline excluisve
« Reply #935 on: Wed, 17 January 2018, 16:29:50 »
sry,it cant
Offline fublamchu
  • ㅋㅋㅋ
« Reply #936 on: Wed, 17 January 2018, 16:32:07 »
Any idea of when next round will start?
LZ-CE VBlacks
910-CE
Offline excluisve
« Reply #937 on: Wed, 17 January 2018, 16:33:25 »
It may next month or early .
Offline kmba
  • Formerly tameone
« Reply #938 on: Wed, 17 January 2018, 23:05:23 »
I'd love to see WKL option for the top plate next round.
keyboards.
Offline amnesia0287
  • Formerly Amnesia
« Reply #939 on: Wed, 17 January 2018, 23:18:21 »
Oooo I like this idea too. Especially if I could still get an hhkb top too :P. I want a WKL just for the heck of it and cause it takes nice photos, but I know HHKB is what I'd use.
Offline finalarcadia
« Reply #940 on: Thu, 18 January 2018, 07:04:04 »
Love your manufacturing quality exclusive. Any chance for slight design changes round 2? Would like a slightly more refined design. Perhaps get rid of middle piece and make weight go through bottom piece, like the X60. Or a weight in the back, like the evil80.
Sent from my SM-G950U using Tapatalk
Offline excluisve
« Reply #941 on: Thu, 18 January 2018, 07:27:59 »
Thank so you advise
I may think of it :)
Offline raymogi
« Reply #942 on: Thu, 18 January 2018, 08:37:41 »
The side profile is so sexy. Definitely regret missing the first round but for sure will be joining the next round.
Please feed my addiction.
Offline gaiden
« Reply #943 on: Thu, 18 January 2018, 08:44:42 »
I don't think taking out the middle piece to make it look more like the other keyboards would be a good idea. Sure there are plenty of room for improvement but in small amount. We can't have every keyboard looking like x60 or evil80 there needs to be some separation in design otherwise why even bother making it? Unless its a faulty design, making dramatic changes would do more harm than good IMO.
Offline ptiede
« Reply #944 on: Thu, 18 January 2018, 09:55:19 »
I'm in agreement with this. I love the current design of the e6-v2. The middle piece is refreshing and makes the board more unique.
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #945 on: Thu, 18 January 2018, 10:54:45 »
I'd be hard pressed to not join the next round if a WKL option were offered.
Offline kmba
  • Formerly tameone
« Reply #946 on: Thu, 18 January 2018, 13:43:01 »
Definitely don't take out the middle piece. That's what makes the board special.
keyboards.
Offline GeneriksGiraffe
  • Living the Rubber Life
« Reply #947 on: Thu, 18 January 2018, 16:35:37 »
When is the next round happening?
SOMEONE PLEASE SELL/TRADE ME AN HHKB PRO 1
Offline afrokobe
« Reply #948 on: Thu, 18 January 2018, 17:37:40 »
yea definitely dont take mid piece out, gives a world of color combos ;)  I wouldn't mind if the led holes were filled though I never have underglow on
Offline excluisve
« Reply #949 on: Thu, 18 January 2018, 20:23:16 »
Next month or later
