Author Topic: [GB] Cherry MX Silent Black Switches - Shipping Update  (Read 214967 times)
Offline wholypantalones
  • text and icon mods plz.
Re: [GB] Cherry MX Silent Black Switches - Shipping Update
« Reply #300 on: Fri, 08 December 2017, 11:48:27 »
Until someone posts irrefutable proof by actually putting nickels on the two different switches proving that these springs are definitely lighter, I would hold off on getting your panties in a bunch about this. You can't tell a spring weight by looking at them side by side with another spring.
I don't have enough coins, is this good enough? (compared to a normal black, silent black is bottomed out while normal black is a bit over 50% depressed)
Edit: I could have swapped the spring to make it lighter so everyone freaks the **** out, if you don't believe what I'm saying providing pics with coins on top of a switch proves nothing
Is holding two switches together enough? Maybe I'm just dim, but what does that accomplish?
It's a pretty decent test.  I tried this with several switches that had the same springs in them.  They all depressed fairly evenly (both stems approximately the same distance into their housings).  However, if you take springs with different force curves, you'll see some back and forth pushing in this test.  Maybe the actuation is the same, but the force curve is different/lighter after actuation.
interesting, I have some silent blacks / silent reds I bought months ago. I guess I'll have to try this and see what the difference is between vintage blacks and reds / silent reds. I'm using the silent blacks in my Filco and I didn't notice a difference in spring weight.
Offline KaosJ
« Reply #301 on: Fri, 08 December 2017, 15:24:31 »
Many people get their switches already and still no coin test.
I just installed them on a board and they definitely feel much lighter than sennin32's plate mounted silent blacks. I don't mind it at all anyway.
Please, since you have 2 different silent black, can you just do the coin test for us?
Offline TalkingTree
    • My projects
« Reply #302 on: Fri, 08 December 2017, 16:01:29 »
VicareyG's on the right, sennin32's on the left.
Excuse the poor pictures' quality. Anyway you should notice that VicareyG's blacks bottom out with seven coins while sennin32's don't.
For reference, those are three fifty eurocent pieces and four two euro coins.
Offline Vadurr
  • Valar Morghulis
« Reply #303 on: Fri, 08 December 2017, 16:06:21 »
Hmmm :\
Offline kawasaki161
« Reply #304 on: Fri, 08 December 2017, 16:52:28 »
inb4 someone is still not convinced because it weren't 'murican nickels
Offline KaosJ
« Reply #305 on: Fri, 08 December 2017, 17:10:01 »
First of all, thanks a lot for the pics.
To resume you put a total of 57.4g weight and VicaryG silent black bottomout while sennin silent black doesn't (and in fact it shouldn't).
A Cherry MX Black should actuate at 55-60g and should bottomout at 75-80g, so the sennin silent black has the right behaviour of a black.
Also, these springs, i counted 9 COILS on the left, 12 COILS on the right, the spring is clearly different.
Also 2, Cherry MX Red has a ~54g bottomout, so the theory of cherry mx red spring might be true, don't have any cherry red on my hands now so i can't check out the mx red spring (maybe someone here can tho).
Not sure what happened on this but i will definetely follow it because i didn't wanted such a light spring and i would be disappointed receiving them.
For now, just sad  :(
Offline xondat
  • i'm not a star
« Reply #306 on: Fri, 08 December 2017, 17:24:02 »
Well this sucks. Got 480 for Christmas hoping they were normal...
Offline TalkingTree
    • My projects
« Reply #307 on: Fri, 08 December 2017, 17:28:41 »
Alright, who's organizing the springs GB then?
Offline KaosJ
« Reply #308 on: Fri, 08 December 2017, 17:29:32 »
360 here, same :(
Anyway that's totally on Cherry, they wrote everywhere that the silent black has 60g actuation and 80g bottomout.
Also Novelkeys said that his other pcb mounted silent has the same spring, so probably their whole batch of PCB mounted silent black are ****ed up.
Not really sure how they put the wrong spring inside, but this will be a huge problem to solve honestly, not sure how they want to fix this.
Offline KaosJ
« Reply #309 on: Fri, 08 December 2017, 17:32:44 »
Pretty sure we shouldn't, Cherry highly ****ed up here.
Please VicaryG contact them and tell them about the problem (showing some of our weight methods), seems like an unnoticed error on their side  for all the Silent Black PCB mounted.
Offline DreLLin
« Reply #310 on: Fri, 08 December 2017, 17:36:28 »
Ok did a full test series with Retooled Blacks, Vintage Blacks, Silent Blacks from GB, Silent Reds and Silent Blacks from Reichelt.
Got the weight of the € Coins from https://www.mdm.de/muenzwelt/euro-muenzen-uebersicht/gewicht-euromuenzen
From left to right: Retooled Blacks, Vintage Blacks, Silent Blacks from GB, Silent Reds, Silen Blacks from Reichelt
Retooled Black ~84g
Vintage Black ~78g
Silent Black from GB ~55g
Silent Red ~52g
Silent Black from Reichelt ~67g
Springs from left to right: Retooled Blacks, Vintage Blacks, Silent Blacks from GB, Silent Reds, Silen Blacks from Reichelt
Left Silent Black from GB vs Silent Black from Reichelt on the right
Full Album: https://imgur.com/a/7E2qV
Offline KaosJ
« Reply #311 on: Fri, 08 December 2017, 17:53:08 »
Retooled Black ~84g
Vintage Black ~78g
Silent Red ~52g
Thanks.
So the Reichelt (plate mounted) is the same spring of all the other MX black (and they probably have a lower bottomout because of the reduced travel), while the GB silent black (pcb mounted) is confimed to have a spring much similar (if not the same) to MX red/MX silent red.
Thanks Cherry :confused:
Offline duynguyenle
  • Personal text? What personal text???
« Reply #312 on: Fri, 08 December 2017, 20:22:12 »
Interesting findings, thanks all for documenting spring behaviour. Seems someone at Cherry ****ed up the spring spec. I was gonna spring swap all the ones I got anyway, so all in all this probably doesn't actually impact me all that much, but I would be interested to know what remedy/renumeration the distributor/manufacturer can offer us in this case, and before it comes to that, where the responsibility lies, seeing as they are two separate entities (right? I am assuming George didn't order them direct from Cherry)
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
« Reply #313 on: Fri, 08 December 2017, 22:32:42 »
Very nice write-up, DreLLin.  Odd as it sounds it does seem like Cherry produced a bunch of silent reds with black stems.
Offline hansichen
« Reply #314 on: Sat, 09 December 2017, 00:08:39 »
I would have changed the springs for lighter ones so it saves me some work, but that should definetly not happen.
Offline Giorgio
« Reply #315 on: Sat, 09 December 2017, 02:33:37 »
Me too :-)
Offline Vadurr
  • Valar Morghulis
« Reply #316 on: Sat, 09 December 2017, 02:46:05 »
I hope cherry is able to remedy this somehow  :-\
Offline ojrask
  • juuh elikkäs
« Reply #317 on: Sat, 09 December 2017, 03:13:37 »
Aw man, I wanted blacks for the weight they're known for. Any idea if replacements are in order or if we have to resort to spring swapping? I've never spring swapped so it would not hurt to learn though.
Current:
Coming up:
IC/GB:
Offline joey
« Reply #318 on: Sat, 09 December 2017, 03:27:36 »
I also bought these blacks to replace my reds which were too light :(
Offline TalkingTree
    • My projects
« Reply #319 on: Sat, 09 December 2017, 03:35:12 »
Even if Cherry provided free black springs, we would still have to pay for the shipment as VicareyG is the actual only customer to Cherry.
I have some standard reds on a keyboard and it actually feels the same of these ones.
Offline KaosJ
« Reply #320 on: Sat, 09 December 2017, 03:59:16 »
I doubt Cherry should provide only the springs, on 96k switches i'm pretty sure many didn't wanted to open the switch at all.
This is a weird situation, not sure which could be the fair solution.
Offline TalkingTree
    • My projects
« Reply #321 on: Sat, 09 December 2017, 04:30:11 »
Tell me about it. I have 600 pieces.
Offline KaosJ
« Reply #322 on: Sat, 09 December 2017, 04:40:35 »
I hope you didn't planned to open them ALL now :(
Since we are both in Italy, we should pay a slavery service to open 1000 switches for us
Offline TalkingTree
    • My projects
« Reply #323 on: Sat, 09 December 2017, 04:52:30 »
I have two full size boards to give as gift and, lucky, silent reds in disguise will do. That trim the numbers down to like 400.
Good idea but let's discuss that in private.
Offline Prelim
« Reply #324 on: Sat, 09 December 2017, 05:01:52 »
Cherry should provide the original Silent Black springs at least! (67g as shown above)
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline KaosJ
« Reply #325 on: Sat, 09 December 2017, 05:04:59 »
I believe that the real silent black spring is the same of blacks (so not 67g) but it will result in 67g because of the reduced travel, make sense?
Offline mgsickler
« Reply #326 on: Sat, 09 December 2017, 05:50:15 »
I received the our batch of switches last night, all 48,000 of them.
They definitely do have springs that are lighter than MX Blacks, and just a hair heavier than MX Silent Reds. The crazy part about all of this is that they match the silent blacks in my Cherry G80 Keyboard. This is not an isolated issue with our batch, but it would seem an issue with a lot of Cherry PCB Mount Silent Blacks. I dont have Plate Mounted Silent Blacks to test these against, but the previous write up is pretty damning.
If anyone would like to cancel their order with me, I will allow it because of this issue. Please notify me (via email with your order number) before the end of Sunday, as I am going to try to get these all in the mail on Monday.
Offline KaosJ
« Reply #327 on: Sat, 09 December 2017, 05:51:55 »
It is crazy that their whole batch of pcb mounted silent black is ****ed up and no one ever noticed it.
Offline VicareyG
  • Vendor - Optic Boards
    • Optic Boards
« Reply #328 on: Sat, 09 December 2017, 05:53:20 »
I have contacted the distributor about this. I don't expect a reply until Monday since it is a weekend however.
I will keep you all updated with any news I receive.
Offline mgsickler
« Reply #329 on: Sat, 09 December 2017, 06:12:32 »
No doubt. It is truly insane.
Offline funderburker
« Reply #330 on: Sat, 09 December 2017, 07:18:33 »
Oh man, this **** up by Cherry is just  :eek: !
I jumped on this GB because of the spring weight as Red would've been too light for me. Sad to see this coming up given previous mishaps already. I'd be fine with opening up switches and changing the springs BUT I think that shouldn't be necessary for those of us who would've been fine with MX Black springs.
There's probably a super low percentage that Cherry would send us 96k of springs.
Oh well...  :'(
Keyboard design by Skepur
Offline KaosJ
« Reply #331 on: Sat, 09 December 2017, 07:25:34 »
Oh well...  :'(
Sending springs is probably the wrong solution to this, since this was a GB :/
Offline TalkingTree
    • My projects
« Reply #332 on: Sat, 09 December 2017, 07:55:24 »
I'm afraid there's no other solution.
Offline KaosJ
« Reply #333 on: Sat, 09 December 2017, 08:02:37 »
No i mean even a refund or partial refund is the way to go (depending on how good Cherry will handle this).
Sending springs is the wrong way because this was a GB, so VicaryG will have to sort, pack and ship springs too, without even considering shipping cost.
Also many didn't planned to open their switches so sending spring will not change anything to them because they clearly wanted a silent black working out of the box without modifications, remember that we actually bought Cherry MX Silent Black, not DIY parts to assemble a Silent Black, so cherry had to provide a fully working silent black, not something that we have to "modify" and put effort into it.
« Last Edit: Sat, 09 December 2017, 08:06:34 by KaosJ »
Offline xondat
  • i'm not a star
« Reply #334 on: Sat, 09 December 2017, 09:25:39 »
The springs are out of specification, so something definitely will happen.
It'll probably be something along these lines:
We figure out how many are affected, probably all of them; George reports to the vendor; vendor figure out how many of their switches are affected; vendor reports to Cherry; Cherry figure out number affected and find the best solution (which will probably be partial refunds); vendor gets partial refund; then George; then us.
Thanks.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #335 on: Sat, 09 December 2017, 09:35:40 »
Can we wait until we receive contact from Cherry? I hate that it'll put shipping to hold, but I'd like to hear what Cherry has to say regarding the issue. Would they recall the switches? I got 5 packs, and given they are not all for my personal use, I would argue it'd be best if I had switches that matched the correct specifications. I'm torn as to whether I should request a refund, as I personally still prefer to type on lighter switches, although my ideal range is actually between reds and blacks.
Sent from my SM-G935T using Tapatalk
Offline mgsickler
« Reply #336 on: Sat, 09 December 2017, 10:01:56 »
The big problem with waiting to hear back is having no idea when or  if we will even hear back from Cherry. If people would like me to hold off on shipping their orders, I can do that as well. If I don’t hear anything, I would still really like to get these shipped out.
« Reply #337 on: Sat, 09 December 2017, 11:22:52 »
I'd rather not wait for these to ship because of springs, I know this is an issue for most people but it's not that big of a deal for me.
Offline xondat
  • i'm not a star
« Reply #338 on: Sat, 09 December 2017, 11:33:48 »
Not ordered from you, but if I had the option with George, I think it should be an opt-in for shipping, not an opt-out. Not everyone follows the threads, or may not have access to internet (say on vacation or something). Unfortunate all around.
Offline xantiema
« Reply #339 on: Sat, 09 December 2017, 12:11:32 »
Pretty much the same here - these practically bottom out if I sneeze on them the wrong way ^-^
Offline mgsickler
« Reply #340 on: Sat, 09 December 2017, 12:12:02 »
I tried to send out a mass email to everyone from my site. It says it went through, but I have no real way of knowing.
People who joined with me, could you let me know if you got my email? If not, I will go through and try to email everyone individually.
I'll be offering 3 choices
1) Cancel and refund
2) Ship out right away
3) Wait until we hear back from distributor and/or cherry
Offline zacheadams
« Reply #341 on: Sat, 09 December 2017, 12:32:40 »
Didn't get the email you just sent (yet?) - but I'd prefer to get them ASAP since I've got springs on deck to swap in.
Thanks for handling this plausible nightmare and thanks to VicareyG too, this is definitely not his fault either, just very very weird and very very unfortunate.
Offline xantiema
« Reply #342 on: Sat, 09 December 2017, 12:35:06 »
This is obviously on Cherry and no one else, also quite well handled by GB organizers considering the messy situation.
Cherry however needs to somehow make this right. For someone only using Blacks, it isn't fun having to compromise with Reds.. the feeling is worlds apart.
Offline mgsickler
« Reply #343 on: Sat, 09 December 2017, 12:40:19 »
Thanks for letting me know. I went ahead and just sent everything out manually.
Thanks for being cool about this too!
« Reply #344 on: Sat, 09 December 2017, 12:42:21 »
I got it, I'm going with #2 and not replying.
Offline zacheadams
« Reply #345 on: Sat, 09 December 2017, 12:43:11 »
Whether it was manual or automatic, I just got an email from ya.
Offline roostrc0gburn
  • its just plastic
« Reply #346 on: Sat, 09 December 2017, 12:50:18 »
so.. you need a response from the email? just ship mine, please
Offline mgsickler
« Reply #347 on: Sat, 09 December 2017, 12:58:36 »
No response needed if you are wanting them shipped.
Offline Atredl
« Reply #348 on: Sat, 09 December 2017, 13:07:12 »
I got your email. Went with option 2 since I was going to swap in lighter springs anyway.
Offline Kavik
« Reply #349 on: Sat, 09 December 2017, 13:16:52 »
I'm rather conflicted on this because I do not want them at all if they have red springs, even with a partial refund (if that is the ultimate solution). I don't mind swapping springs if those springs are provided as the solution. But, if I get a full refund on this, I'll be paranoid that any other source of silent blacks will have this same problem since the bad batch may be larger than just our order. I also don't want to screw over NovelKeys by leaving it with bad inventory that will be paid out of pocket if I get my money back. Crappy situation. I'm leaning towards option 3, but I'll send my email later today confirming that.
