Author Topic: PSA: Keycaps getting stuck due to extra plastic  (Read 2997 times)
Offline Special K
« on: Sat, 29 July 2017, 13:05:27 »
I recently bought a GMK keycap set and noticed that a few of the keys weren't bottoming out.  Instead of a "clack", I was hearing a muted "thunk".  At first I thought this was a manufacturing defect - maybe the hole for the switch stem wasn't quite deep enough, preventing the keycap from being pressed all the way onto it.  Upon closer inspection, I saw that there was a piece of plastic left behind from the manufacturing process:
This extra plastic piece was catching on the switch mount, preventing the keycap from fully bottoming out.  I just took an xacto knife and trimmed off the extra piece, and the keycap was fine after that.
I don't have anything else to add; just check underneath your keycaps if some of them aren't bottoming out.  This is my second GMK set and the first one didn't have any keys with this issue.  I've never bought any other brand of custom keycaps, so I don't know how common this issue is.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline FrostyToast
  • Litshoard
Re: PSA: Keycaps getting stuck due to extra plastic
« Reply #1 on: Sat, 29 July 2017, 13:25:16 »
If your keyboard has LEDs on the switches, then that would be your problem. Cherry caps weren't intended to be used with LEDs and it is a known issue.
Quote from: elton5354
Offline FrostyToast
  • Litshoard
« Reply #2 on: Sat, 29 July 2017, 13:28:57 »
Actually, I see that the crossbar is longer on one side. Interesting manufacturing error.
Offline Special K
« Reply #3 on: Sat, 29 July 2017, 13:35:00 »
My keyboard is just a standard Filco, so no LEDs.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline Special K
« Reply #4 on: Sat, 29 July 2017, 13:35:48 »
It's centered the same as all of the other keycaps in the set, it's just the other keycaps don't have anything in that space, whereas this one (and 5 others in my set) has that little stub of plastic left behind.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline rustywok
« Reply #5 on: Sat, 29 July 2017, 13:47:28 »
I had that issue with my GMK Honeywell set. I fixed it by using an x-acto knife to slice off that little spur of plastic clinging to the stem.  Turns a dull thud back into a click that matches the rest of the set.
