Author Topic: My Ideal layout  (Read 1810 times)
Offline irad
My Ideal layout
« on: Sun, 30 July 2017, 03:55:42 »
This is my Ideal layout for a keyboard...
Which Mechanical keyboard with similar layout and Cherry Mx switches should I buy?
Offline Krakob
    • Krakblog
Re: My Ideal layout
« Reply #1 on: Sun, 30 July 2017, 04:32:19 »
There's two problems with this layout:
1. Doing arrow keys like that is impossible with Cherry MX, as they are too big and must occupy at least the space of a 1x1 key (e.g. any letter).
2. Keyboards in this size but without the topmost row are usually known as 60% and are pretty common. Ones with the topmost function row are sometimes called 70%, but are generally pretty uncommon.
I suggest looking at kbd75 (a bit larger) or XD60 (a bit smaller)
Ducky Shine 2 (MX Blue, white backlight) • Obins Anne Pro (Gateron Brown) • Model M • XD60
Offline TalkingTree
    • My projects
Re: My Ideal layout
« Reply #2 on: Sun, 30 July 2017, 05:15:43 »
Your closest match is the A-Jazz AK33.
