Author Topic: kbfirmware.com config (wiring/pins) for ISO GH60 Satan board?  (Read 3387 times)
Offline kimusan
  • Mechkeys Tech
    • Mechkeys Tech
Hi,
I am looking for a config file (json) for a GH60 Satan (CHrev) in ISO layout - more specifically for the wiring/pin layout. I tried creating one from scratch but something has gone wrong and the keyboard will not start after flashing (using QMK flasher in windows).
I was hoping that someone already had this file so I could just re-use it as a template for my layout.
Offline TalkingTree
    • My projects
Re: kbfirmware.com config (wiring/pins) for ISO GH60 Satan board?
« Reply #1 on: Mon, 31 July 2017, 06:17:16 »
Not sure if it's the same for you, but you can generate a firmware online through the TMK Keymap Generator by choosing GH60 (RevCHN), located under second-party, and pasting your layout from the KLE.
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #2 on: Mon, 31 July 2017, 07:05:46 »
Yes, this method is the easiest. You can then flash it to your keyboard using the standard TKG-Toolkit.
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline kasakka
« Reply #3 on: Mon, 31 July 2017, 07:39:48 »
Any reason why you're not just using EasyAVR for mapping?
