Author Topic: Thinking of a WANG  (Read 6880 times)
Offline didjamatic
Thinking of a WANG
« on: Sun, 07 March 2010, 22:10:36 »
I'm thinking of biting on one of these WANGs.  He's gone down several times since he first listed one.  Now he's at 27.
Wang 724
Has anyone in here taken a WANG from this guy?
Offline Brodie337
Thinking of a WANG
« Reply #1 on: Sun, 07 March 2010, 23:33:33 »
So... Many... Bad... Punns!!!
What are the three keys under Del/End/PgDn?
Offline Brodie337
Thinking of a WANG
« Reply #2 on: Sun, 07 March 2010, 23:35:51 »
Offline TexasFlood
Thinking of a WANG
« Reply #3 on: Mon, 08 March 2010, 00:07:39 »
Quote from: didjamatic;162422
Wang 724
Looks like a decent deal.  However looks lke you might get black, orange or pink ALPS switches and from that particular deal seemingly no cable is included so you'd have to buy or fabricate your own RJ45<>PS/2 cable to plug it in.  Actually I see now that the same vendor sells the cable separately for US $18.95 (or make offer) + shipping $12.58UPS ground.  Says they're making the cables since the boards didn't include them.  Certainly raises the overall cost.  Maybe not too high if it's a quality built board but might not knowing what ALPS switch you'll get be an issue?
Offline TexasFlood
Thinking of a WANG
« Reply #4 on: Mon, 08 March 2010, 00:53:42 »
.....he said "WANG", huhuhu.. huhuhu....
Offline sixty
    • http://deskthority.net
Thinking of a WANG
« Reply #5 on: Mon, 08 March 2010, 01:56:34 »
One of the Korean guys over at kbdmania had ordered one of the NIB WANGs.
Apparently they use black ALPS:
http://ejlabs.net/kbd/xe/?vid=kbd&mid=textyle&act=dispTextyle&search_target=title_content&search_keyword=wang&x=0&y=0&document_srl=99
Unless you plan to change switches or have some obscure fetish for terrible ALPS switches I suggest staying away until he drops them to like 10 bucks :D
Offline J888www
Thinking of a WANG
« Reply #6 on: Mon, 08 March 2010, 02:22:34 »
If they are from the same batch as the previous listings, then they have ALPS Black Switches = non clicky. The KBD is quite solid, much better than the Chiconys in comparison and most importantly, its new = no necessity for viral protection. The "not included" cable is a matter of concern, you would want a keyboard to be able to plug-in and usable. So if no cable then = useless. Fabricating your own cable is quite simple but if you are not definitely certain then you risk the death of your comp or KBD or both.
For those who prefer ckicky switches, it can be modified by snapping/breaking the four protruding tabs from all the corners of switch leaves. After this mod, the switches will have a "soft" click.
If this KBD is supplied with cables at the same cost, then I would definately purchase another.
« Last Edit: Sat, 13 March 2010, 12:04:15 by J888www »
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline didjamatic
Thinking of a WANG
« Reply #7 on: Mon, 08 March 2010, 06:54:25 »
I contacted the seller when he first put the boards on ebay and the price was around $100 and he said they were Black switches.  Thanks for the link sixty.
If they were dampened switches, I'd get one as I don't have a dampened ALPS keyboard.
Good call on the cable, I never noticed that before and will probably hold off because of that.
« Last Edit: Mon, 08 March 2010, 06:58:48 by didjamatic »
Offline fastbuck
Thinking of a WANG
« Reply #8 on: Mon, 08 March 2010, 08:10:35 »
I got one a little while ago - feels very solid, switches are non-clicky black alps. I'm going to make the cable - Sandy showed the schematic, looks simple, though I haven't gotten to doing it yet.
Keyboards: IBM Model M 1391401, CVT Avant Stellar, CVT Avant Prime, Dell AT101W, TypeMatrix 2020, Compaq MX 11800, Chicony KB-5181, IBM M-13, Chicony KB-5191, Wang 724,
Pointing devices: Contour Rollermouse & Pro, Microsoft Intellimouse Trackball, Kensington TurboBall Trackball, Evoluent Vertical Mouse, 3M Ergonomic Mouse, Zero tension mouse, MS Ergonomic Laser Mouse 6000, Logitech TrackMan Wheel, Wowpen Vertical mouse, Logitech Trackman Marble, Digital Research DRTRACK Trackball
Offline eunjea
    • http://kbdholic.net/
Thinking of a WANG
« Reply #9 on: Mon, 08 March 2010, 17:39:14 »
Quote from: sixty;162475
I made cable too. ;-)
http://ejlabs.net/kbd/xe/kbd/127
« Last Edit: Mon, 08 March 2010, 17:42:34 by eunjea »
Offline TexasFlood
Thinking of a WANG
« Reply #10 on: Mon, 08 March 2010, 20:38:43 »
Quote from: didjamatic;162513
It can be tricky.  For example, this Wang 724...  Well not only is it "untested" but also shows a cord included.  However, close examination of the pictures reveals that it has RJ45 connections at both ends such as a phone cord, which would not allow it to be used.  Now, you could probably modify it to work but would be a disappointment for anyone hoping to plug it in and use it.
« Last Edit: Mon, 08 March 2010, 20:43:03 by TexasFlood »
Offline InSanCen
Thinking of a WANG
« Reply #11 on: Tue, 09 March 2010, 01:08:32 »
If someone grabs one, can you post the date, serial, and any other relevant numbers?
I ask because mine takes pink's, and if we get enough data points, we may be able to have a rough estimate on when they switched over.
The cord, if it's any help, should be RJ11 to PS/2. The seller has them Link, but is not including them. It's relatively easy to make one.
« Last Edit: Tue, 09 March 2010, 01:10:54 by InSanCen »
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline eunjea
Thinking of a WANG
« Reply #12 on: Tue, 09 March 2010, 01:40:14 »
Quote from: InSanCen;162676
Here
Black Alps
HTH
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Thinking of a WANG
« Reply #13 on: Tue, 09 March 2010, 19:41:46 »
Quote from: TexasFlood;162645
Do those Wang 724's use the PC/AT keyboard protocol?
Offline skriefal
Thinking of a WANG
« Reply #14 on: Tue, 09 March 2010, 19:42:34 »
I believe I'm local to you (in SLC?) and have a 724 that I'd be willing to let go of.  It's not NIB, but no shipping cost either. :smile:  Let me know if you're interested.
Offline InSanCen
Thinking of a WANG
« Reply #15 on: Fri, 12 March 2010, 17:58:24 »
Quote from: eunjea;162682
Here
Black Alps
HTH
hmmmm...
Mines a 92, week 28.
If I can get some more datapoints, I'll compile a spreadsheet and see if I can a changeover perios so people can get a better idea of the liklehood of Pink or Black ALPS.
Offline fastbuck
Thinking of a WANG
« Reply #16 on: Sat, 13 March 2010, 10:35:32 »
Quote from: microsoft windows;162836
Yes
Offline J888www
Thinking of a WANG
« Reply #17 on: Sat, 20 March 2010, 13:51:42 »
Made the cord with an IBM M SDL to PS/2 cable (replaced the SDL connector with a RJ11 (6 pin) connector). The colour of the IBM cable wires did not match with the wires of the WANG. After scrutinising the SDL connector, I arrived at the conclusion that:
  Looking from the bottom of the KBD connector with Sandy55 info to match the IBM Cable wire colour.
1} KBD White wire = Clock = IBM cable Brown wire
2} KBD Black wire = Data = IBM Cable White wire
3} KBD Red wire = N/C = Blank
4} KBD Green wire = Ground =IBM Cable Black wire
5} KBD Yellow wire = +5V = IBM Cable Red wire
6} KBD Blue wire = Shield = Metal Wire (bare)
Please note that this applies to the IBM M SDL to PS/2 cable, other cables may have different colour coded wiring, so you will need to check which represents "Data", "+5V", "Ground" etc etc etc.
Skeptical when I connected to my PC, then powered on. To my elation, it worked perfectly with a extra pleasant surprise. I had forgotten there was a small speaker on this KBD, and every key stroke produced a bleep sound which can be turned louder or quieter from the back of KBD. So modding this ALPS Black switches KBD to become clicky is unnecessary and this bleep/noise is uniform which may/may not apply to clicky switches.
To summarise this WANG 724 = "Delightful"
« Last Edit: Thu, 08 July 2010, 19:39:44 by J888www »
Offline iMav
  • geekhack creator/founder
Thinking of a WANG
« Reply #18 on: Sat, 20 March 2010, 17:11:46 »
Looks like they are now available with cable.
Offline J888www
Thinking of a WANG
« Reply #19 on: Sun, 21 March 2010, 04:41:31 »
It's more convenient to purchase with a cable, but for me, the satisfaction is to make one. For those who have cash concerns and expendable time, the cost to make = 1 old cable + £0.20/$0.30 (J11 6Pin plug), cost of cable with shipping ?
This KBD is a little more enticing than others because of good build quality and more importantly, as time passes, it will become more difficult to find one which is NEW.
