Author Topic: Alps/MX plate thickness  (Read 2280 times)
Offline Thereminz
« on: Sat, 05 August 2017, 13:18:39 »
So using the swill builder you can make a plate that has holes for alps and mx switches combined
I know the switches won't fit perfect  in either but i was also wondering what thickness you would use anyway for a plate like that since mx thickness is usually 1.5mm and alps i hear is 1.2mm
Offline 0100010
  • Not Sure
Re: Alps/MX plate thickness
« Reply #1 on: Mon, 07 August 2017, 21:30:38 »
Alps max is 1.6mm, so typically a 0.06" plate will work for both cherry (1.5mm) and alps (1.6mm).
Offline Thereminz
« Reply #2 on: Mon, 07 August 2017, 22:31:42 »
ok thanks :thumb:
