Author Topic: Hydrogen peroxide against yellowed plastic.  (Read 3060 times)
Offline vils
« on: Tue, 09 March 2010, 02:30:09 »
Hydrogen Peroxide seem to work like a charm when restoring old computer parts.
http://retr0bright.wikispaces.com/
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline sethstorm
« Reply #1 on: Tue, 09 March 2010, 14:42:36 »
So that's what was used.  I just don't have a ton of yellowed-plastic hardware to test it, but I do have Hydrogen Peroxide.
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
