Author Topic: [IC] GMK Lavender Field  (Read 5983 times)
Offline BlueParrot
« on: Mon, 07 August 2017, 09:04:48 »
Hi everyone! I wanted to show you guys GMK Lavender Field. This set was inspired by lavenders, hence the name. I did get some initial feedback from Reddit about a week ago and things seemed good enough to me to continue developing the set, bringing us to the IC stage. Nothing is final at this point and feedback is encouraged. Please let me know if I'm missing anything in any of the kits.
Notes:
   ISO things moved to international kit
Kits Planned:
   1. International
   2. Colemak + Dvorak
   3. Ergodox + Planck
   4. Spacebars
Light theme - http://imgur.com/a/Epxa6
Dark theme - http://imgur.com/a/P209K
Google Form - https://goo.gl/forms/i7hZFboLkYnfvG0M2
Show your support with this!
Code: [Select]
[url=https://geekhack.org/index.php?topic=90957.0][img width=500 height=150]https://i.imgur.com/sBrJTft.png[/img][/url]
« Last Edit: Mon, 07 August 2017, 09:22:43 by BlueParrot »
Offline afrokobe
Re: [IC] GMK Lavender Field
« Reply #1 on: Mon, 07 August 2017, 09:11:33 »
change the legends to yellow so I can have GMK Kobe
Offline Rykno
« Reply #2 on: Mon, 07 August 2017, 09:19:27 »
^ this ****ing guy :p
Offline Peiweisgreat
« Reply #3 on: Mon, 07 August 2017, 11:05:51 »
Not too sure about the green on grey. It looked a little hard to read at first glance, so maybe a darker grey or darker green would make it look a litlte bit nicer.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #4 on: Mon, 07 August 2017, 13:25:44 »
I believe so too, it will probably have contrast issues.
Offline amnesia0287
  • Formerly Amnesia
« Reply #5 on: Mon, 07 August 2017, 15:14:37 »
I think it would look nice with the base of Hydro (GR1) or Hyperfuse (2M). But I'd buy it either way :D. Purple & Green is gud.
Offline BlueParrot
« Reply #6 on: Mon, 07 August 2017, 16:16:29 »
I thought the same when I started the IC and was leaning towards the light theme, but some people on Reddit mention the legend color being a bit harsh on the eyes.
Offline InTheFlesh
« Reply #7 on: Fri, 11 August 2017, 11:50:00 »
Interested
