Author Topic: Stepped Caps Lock Key Sources for Cherry G80-3000?  (Read 3054 times)
Offline Riverman
« on: Tue, 08 August 2017, 15:02:32 »
Can anyone recommend a seller of stepped caps lock keys with offset stems to fit a Cherry G80-3000?  About the only ones I've seen come as part of fairly expensive sets.  Tai-Hao makes some ABS ones, which would be fine, but I've never seen anyone who actually sells them.
Re: Stepped Caps Lock Key Sources for Cherry G80-3000?
« Reply #1 on: Tue, 08 August 2017, 15:33:05 »
They can be had on Taobao for about $5.
