Author Topic: Fixing delayed key inputs on Access-IS AKE104696/1-STK15  (Read 1909 times)
Offline pabile
    • pabile online
« on: Wed, 09 August 2017, 02:42:56 »
Hello GH!
I was able to acquire an Access-IS keyboard with PN AKE104696/1-STK15. I like the build but there are delays in key inputs/registrations. I tried plugging it's serial port thinking that it might pull more power and fix the issue. Still no good.
I thought that giving this keyboard new controller is the best approach. My question is, where do I start? I have spare teensy clone but will acquire teensy if really needed.
Here's something about the keyboard:
175397-0
175399-1
Ribbon that connects the actual keyboard from the reader/scanner. Can I tap on to these and connect to pro micro? Which pin goes where? How would I know the keyboard's matrix?
175401-2
175403-3
Keyboard mouse pointer. I wish to make this work with the controller as well. Will 1 controller be enough? I saw hasu's TMK has orphan project named serialmouse_usb. Will that work?
175405-4
There are two atmega161 soldered on the reader/scanner board. Can i use this isntead of external/separate contrller? Just curious but... I honestly wish to keep it as is and make the scanner work for some other projects.
175407-5
175403-6
So... whare do I start?  :D
Thanks GH!
« Last Edit: Thu, 10 August 2017, 00:23:54 by pabile »
Offline pabile
    • pabile online
Re: Fixing delayed key inputs on Access-IS AKE104696/1-STK15
« Reply #1 on: Thu, 10 August 2017, 00:24:52 »
I'm reading this thread and will try when I get back on the keyboard: https://deskthority.net/workshop-f7/reversing-a-keyboard-matrix-t7.html
