Author Topic: Thoughts on plateless Let's Split on tented wood case?  (Read 3424 times)
Offline fnurl
« on: Wed, 09 August 2017, 03:08:05 »
I am thinking about making a wooden tent shaped case for the Let's Split I am about to build (similar to a tented Ergodox).
To keep things simple and modifiable, I would like to skip the plates. Given that the PCBs are so small, my thoughts are that the plates are not as necessary?
Any comments on this idea?
Offline frontier
Re: Thoughts on plateless Let's Split on tented wood case?
« Reply #1 on: Mon, 14 August 2017, 03:41:27 »
I can't respond to whether the PCB holding the switches will be enough, but I wanted to chime in that I'm planning to do the same when my Let's Split arrives although I was planning to use the plate still.
