Author Topic: Ducky DKON 1687 - registering key issue  (Read 1681 times)
Offline Tomasz
« on: Wed, 09 August 2017, 07:25:31 »
Hi there.
I use Ducky DKON 1687 and I use it heavily to play games specifically CS:GO. Whoever is familiar with CS series knows that E is a deafult key you use to defuse the bomb, but going straight to the point once in a while I noticed that when I play the game and want to defuse the bomb, I press E key and hold it, it activates but then 1 or 2 seconds later it deactivates and activates again, eventually I am losing the round because of that.
I tested the keyboard with AquaKeyTest and I noticed that indeed once in a while when I pressed and held E, it would activate, then deactivate soon after, then activate, then deactivate and so on or just at some point it would stay as not active even though I was still holding it down.
What can be the cause for this issue? The keyboard is still under warranty. Should I send it back? It is not very consistent to reproduce and I am slightly worried that they could reject the warranty claim.
BTW Sorry if I have posted it in the wrong section of the forum.
« Last Edit: Wed, 09 August 2017, 07:37:55 by Tomasz »
