Author Topic: Greetings!  (Read 2929 times)
Offline Dead Encryption
  • Dead...
    • Twitch Channel
Greetings!
« on: Wed, 09 August 2017, 19:28:09 »
I am pretty new to the Keyboard Community, just saw some posts on imgur one day and decided I was obsessed with it...haha. I have tons of experience electronic soldering, etc. and am an IT Manager about to start my own consulting company. For my first board I just purchased:
  • Rev2 Zeal60 RGB LED PCB
  • R7 Purple Zealio Switches (Tactile) - 65G
  • Gold Plated PCB Mount Screw-in Stabilizers V2 - 4x 2u, 1x 6.25u
  • 60% Aluminium / Acrylic Sandwich Case & Aluminium Feet
  • G20 "Stealth" Keycap Set (Night Mode Base)
  • DSA "Otaku" Keycap Set (Modifier)
  • 1-Artisan Aluminum 3D Key (Will show once build is done  ;D)
I do have a youtube channel that I have setup and haven't used, but I am intending on making a video of the build as well since I haven't really seen any using the Rev2 Zeal60, etc.
Anyway, I hope to be as active as I can on here and participate when I can and will update posts if I am able to make any videos or take photos.
Have a good one everyone!
Offline raxander
Re: Greetings!
« Reply #1 on: Wed, 09 August 2017, 22:12:46 »
That's going to be a great board!  Congrats.  I have had a problem with the wires popping out on those screw-in stabilizers (as have others), but you can pop them back in if you're patient without desoldering anything.  I like them though and would still use them in the future despite that issue.
  • Dead...
    • Twitch Channel
Re: Greetings!
« Reply #2 on: Thu, 10 August 2017, 08:21:05 »
Thanks for the heads up, I'm also trying to decide if they need to be lubed as well and debating on lubing the switches. My concern was if I lube the switches do I need to get stickers for them as well. Or should I just try out the board without lubricating first.
Offline raxander
Re: Greetings!
« Reply #3 on: Thu, 10 August 2017, 08:50:07 »
If your plate lets you open the switches without desoldering then I guess you could always do it later?  Otherwise I guess it's better to lube them.  I didn't lube my 67g or 78g zealios and they feel great to me but I don't have a direct comparison to lubed ones and I'm not a connoisseur.
  • Dead...
    • Twitch Channel
Re: Greetings!
« Reply #4 on: Thu, 10 August 2017, 08:58:28 »
Ok, I will probably go ahead and lubricate then. I know my case comes with a plate that is supposed to allow that, but better to do it ahead and save a possible headache.  :thumb: Also, for reference to your comment on the stabilizers, did you have Rev 1's or the Rev 2's with those issues?
Offline raxander
Re: Greetings!
« Reply #5 on: Thu, 10 August 2017, 16:09:43 »
Rev 2.
EDIT:  I lubed them with dielectric grease, which may increase the probability of popping out, not sure, haven't tried dry ones.  Like I said above, though, you can pop them back in without desoldering, just takes some patience and long tiny screwdriver or similar implement.  I would consider it a problem if I was making the board for someone else but would still use them for myself.  I also had a problem with the metal screws shorting the pcb (Satan GH60), but that's an easy fix (duct tape yay!) and I really don't think you'll have that issue with the zeal60.
EDIT 2:  I should clarify: they don't randomly pop out during use, only when changing keycaps, and not every time.  So it doesn't affect normal operation.
« Last Edit: Thu, 10 August 2017, 16:47:38 by raxander »
  • Dead...
    • Twitch Channel
Re: Greetings!
« Reply #6 on: Thu, 10 August 2017, 20:31:54 »
Ah ok, well since i've already spent my wallet on this build, I don't think I will be changing keys out anytime soon. Haha, but thanks a lot for clarifying.
