Author Topic: Found a Schneider G81-3026  (Read 2767 times)
Offline gui710
« on: Thu, 10 August 2017, 16:06:43 »
Hey there I'm new to the forum, I was looking for an advice about what to do with a Schneider G81-3026 keyboard, that a friend of my mom gave me a few months ago and I found it today, since the PS/2 connector is somewhat deformed.
This is the keyboard and the PS/2 connector: http://imgur.com/a/IiVnh
Any tips about what I could do about it would be appreciated since I want to clean it and start using it ASAP, also thanks in advance! :)
« Last Edit: Thu, 10 August 2017, 16:23:51 by gui710 »
Offline Tactile
Re: Found a Schneider G81-3026
« Reply #1 on: Thu, 10 August 2017, 16:25:52 »
You can replace it with a 6-Pin Mini Din connector. They are easy to find and don't cost much.
REΛLFORCE
Offline gui710
« Reply #2 on: Thu, 10 August 2017, 16:31:33 »
Thanks a lot for your reply! Where could I find one of those and how difficult would it be to replace it?
Offline Tactile
« Reply #3 on: Thu, 10 August 2017, 16:40:45 »
I don't know what country you're in. Any electronics place like DigiKey or Mouser would have them. I'm sure you could find one on Ebay.
How difficult? - I can't answer that. You'll need to solder the wires to the new connector.
REΛLFORCE
Offline gui710
« Reply #4 on: Thu, 10 August 2017, 16:42:44 »
I live in Portugal and I have a Mouser here but 0 skill with soldering :v
Offline Tactile
« Reply #5 on: Thu, 10 August 2017, 16:50:36 »
The first step is to have the new connector in your hand. Then you can find someone to install it. If you're near a college or university, the electronics instructor would probably have someone in the class do the job for cheap or free. Or go to a musical instrument shop. The people who work on electric guitars and amplifiers could certainly do it.
REΛLFORCE
Offline gui710
« Reply #6 on: Thu, 10 August 2017, 16:55:15 »
Thanks I might do that, I just have one question, the point here is to change the whole cable or just the connector? I'm really confused at this point, I'm really sorry :c
EDIT: Looks like that the connector isn't PS/2 but AT!
« Last Edit: Thu, 10 August 2017, 17:02:26 by gui710 »
Offline Tactile
« Reply #7 on: Thu, 10 August 2017, 17:02:51 »
Snip off the connector, leaving a few centimeters of cable attached.
Strip back the jacket of the cable/connector so you can get to the wires.
Use a multimeter to match the wire colors to the connector pin positions. Write it down.
Disassemble the shell of the new connector (they're all different but come apart in some way so you can get to the terminals)
Prepare the cable by peeling the jacket back, separating the wires, and stripping the wires.
Solder the wires to the terminals, making sure to match the color/position you wrote down.
Assemble the connector shell.
REΛLFORCE
Offline gui710
« Reply #8 on: Thu, 10 August 2017, 17:09:39 »
Would it still work since I just noticed that the connector ain't PS/2 but AT?
Offline Tactile
« Reply #9 on: Thu, 10 August 2017, 17:13:19 »
AT & PS/2 are electrically identical, the only difference is the connector size. PS/2 is the way to go - all the USB converters are for PS/2.
REΛLFORCE
Offline gui710
« Reply #10 on: Thu, 10 August 2017, 17:38:31 »
I'll most likely do what you recommended! Thank you very much and sorry for the whole mess! >_<
