Author Topic: zz96 help please  (Read 2043 times)
Offline DillonHightower
  • Formerly DillonHighsmith
zz96 help please
« on: Wed, 16 August 2017, 00:19:18 »
So i just put together a zz96 and Im having some issues, most likly due to not knowing what I am doing.
1, no leds are working. the pre installed ones on the back are working fine but the ones on switches are not. what am I doing wrong for them not to light up?
2. key strokes work under key hitter, but is there a boot mapper software out there? slightly confused on that . I know it has firmware on-board but how do I customize layout ?
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
Re: zz96 help please
« Reply #1 on: Wed, 16 August 2017, 00:52:40 »
happened to me. for me its because the leds are turned off and i turned it on first using bootmapper.
Also you can follow the link below on how to get it and how to use it.
https://www.massdrop.com/talk/1392/programming-kbd-keyboards-via-bootmapper-client
« Last Edit: Wed, 16 August 2017, 00:58:41 by Krytone »
TGR Jane CE | TX-CP | ZZ96 | HHKB | Ducky Shine 3 | Atreus | Infinity Ergodox | IBM Model M | Smart Pad | Taobao Acrylic 96 | TGR910 SE | RGB96 | M4-A | Moon
Pending: Exent | EM7 | M-60 | Kira EXS | 910 Poly | Kn210 | Alice
« Reply #2 on: Fri, 18 August 2017, 20:47:26 »
thanks buddy, It was needed to get bootmaper going . Once I did that all was great. Board is working good now.. Also great caps dude. Loving them for sure ..
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
« Reply #3 on: Sun, 20 August 2017, 02:01:19 »
glad its working and cool freakin board  :thumb:
