Author Topic: HHKB - Is it Possible to Change Out Topre for MX Switches  (Read 5176 times)
Offline LoveYouFyi
« on: Thu, 17 August 2017, 13:54:31 »
Is it possible to convert a HHKB to use MX Switches?  I'm wanting to try it with the new Cherry MX Silver (SPEED) switches.  I was looking into using Topre 30g, but it would cost $230+ to get a board just for the switches.  Thanks
Offline pingmaster
Re: HHKB - Is it Possible to Change Out Topre for MX Switches
« Reply #1 on: Thu, 17 August 2017, 13:55:14 »
Nope..
Offline sony
  • Formerly ultraidiot
« Reply #2 on: Thu, 17 August 2017, 13:56:26 »
No, but there are a few custom hhkb mx layouts. They can be found on Aliexpress for less than $100. There are also higher end boards like X60, Revo RJ, Duck Viper
Sent from my ONEPLUS A3000 using Tapatalk
Offline LoveYouFyi
« Reply #3 on: Thu, 17 August 2017, 14:12:02 »
Good to know guys, thanks.
Offline rioc
« Reply #4 on: Thu, 17 August 2017, 14:17:32 »
Nope, but check out the tina-60 from kbdfans. The A  layout had the same offset hhkb bottom row
https://kbdfans.myshopify.com/products/tina-keyboard-60?variant=38954516941
Sent from my DREA100 using Tapatalk
« Last Edit: Thu, 17 August 2017, 14:19:13 by rioc »
Offline LoveYouFyi
« Reply #5 on: Thu, 17 August 2017, 14:40:38 »
Great recommendation, the TINA A from KBDFans looks like the closest I can get to HHKB with Cherry MX.  Thank you
Offline ygor
  • eat a butt, monkey lord
« Reply #6 on: Thu, 17 August 2017, 14:47:51 »
This is the greatest thread of all time tbqfhwu, fam.
Offline 0100010
  • Not Sure
« Reply #7 on: Thu, 17 August 2017, 14:58:37 »
No caps come with the TINA A?
Offline afrokobe
« Reply #8 on: Thu, 17 August 2017, 15:07:12 »
just pull hard on the sliders of the hhkb.  once the housings pop out just shove an mx switch in there.  should work...
« Reply #9 on: Thu, 17 August 2017, 15:18:35 »
But the HHKB doesn't have slider housings.....time to break out the jigsaw and hot glue though.....nothing's gonna stop this now... :spam:
Also I'll take a moment to offer they usual PSA, topre boards don't have discrete switches like mx or alps, it's more of a sandwiched assembly.
« Last Edit: Thu, 17 August 2017, 15:23:12 by SpAmRaY »
Offline rioc
« Reply #10 on: Thu, 17 August 2017, 17:28:11 »
No, but if you took spacebar kit from any recent gmk gb you've got a 6u space
« Reply #11 on: Thu, 17 August 2017, 18:16:42 »
No.
