Author Topic: 3D printing feetless translucent case  (Read 3000 times)
Offline kamilakas
« on: Fri, 18 August 2017, 09:38:48 »
Hi there. I've made a feetless case (I'd like to copy Feetless acrylic case, so made this). 3D model is in attachments, also are photos of first version (made mistake with depth, file that's in attachments with corrected depth - 18mm in). Maybe, you have some other models of cases? Give your opinion 'bout that.
« Last Edit: Fri, 18 August 2017, 10:48:36 by kamilakas »
Offline Damonskv
Re: 3D printing feetless translucent case
« Reply #1 on: Fri, 18 August 2017, 09:41:34 »
Great result, congratulations
Offline pingmaster
« Reply #2 on: Fri, 18 August 2017, 09:47:49 »
Can you put an RGB 100W leds :D ? Screw overhead lighting!
Offline TalkingTree
    • My projects
« Reply #3 on: Fri, 18 August 2017, 10:36:44 »
That's a very nice looking case.
Do you mind if I ask you what software is that?
Offline kamilakas
« Reply #4 on: Fri, 18 August 2017, 10:49:44 »
What software is that?
Thanks! It's Autodesk Fusion 360
« Last Edit: Fri, 18 August 2017, 10:51:58 by kamilakas »
Offline TalkingTree
    • My projects
« Reply #5 on: Fri, 18 August 2017, 10:52:02 »
