Author Topic: ADB to USB converter pinpout  (Read 2306 times)
Offline Ruskie
« on: Fri, 18 August 2017, 12:00:18 »
Hello,
I am currently in the process of building an ADB to USB converter, and am in need of pinout in order to finish the design. I have all the materials (ADB cable, Teensy 2.0, and USB cable), so I should be good to go once I get it all wired up. Thanks for your time!
Ive got myself a beefy boi
-Alf F62PE
-PCB Mount ZealV2 67g
-GMK KA1953 "OG Classic Retro"
8 pounds of clack
Re: ADB to USB converter pinpout
« Reply #1 on: Fri, 18 August 2017, 12:05:13 »
Did you check the adb to usb thread?
https://geekhack.org/index.php?topic=14290.0
Offline Ruskie
« Reply #2 on: Fri, 18 August 2017, 12:07:13 »
Awesome. So, from what I am looking at, I am going to need a 1k ohm resistor as well as the materials I listed?
-Alf F62PE
8 pounds of clack
