Author Topic: Getting desperate here! I want/Need Ducky One RGB TKL kb..  (Read 2752 times)
Offline Helvetinbarbaari
« on: Fri, 18 August 2017, 18:31:09 »
..but just can't find one with Mx silvers and ISO nordic keycaps. I could go red/brown, but i don't want to .. :D
This is one option:
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2416 + http://www.wasdkeyboards.com/index.php/products/keycap-set/88-key-iso-cherry-mx-keycap-set.html
but i'm wondering if there is a better way? at least for the caps, those ain't double shot BPT like the originals..
Any ideas where one might find BPT ISO nordic caps for mx keys?
Re: Getting desperate here! I want/Need Ducky One RGB TKL kb..
« Reply #1 on: Sat, 19 August 2017, 05:55:05 »
I'll reply to myself. :P I did some more research and i think i'm even more in love!
http://www.keyboardco.com/keyboard/swedish-topre-realforce-88u-45g-white-keyboard.asp
It has nordic caps, 45g (which seems good for gaming, according to others, no way to test either 45/55), awesome build quality, sounds and it cost only money!  :p
I really like the 80s feel on the beige version + i use it mainly in the "dark", so might be bit better for that than black version.
Anyone else gaming with this beauty? I hear some might say it is too "expensive" for gaming, but i like to get all in one package.
Offline clee290
« Reply #2 on: Sat, 19 August 2017, 11:00:18 »
I haven't used a Realforce, but I've used a HHKB (also rated at 45g, I believe) and didn't have any problems. You can pretty much game on any switch/weight, it just comes down to your own preference.
Offline Entropia
« Reply #3 on: Sun, 20 August 2017, 09:02:26 »
How about this? https://www.candykeys.com/product/varmilo-va88m/
It's premium quality, PBT keycaps, you can customize it with the colors you want (case, keycaps, legends...) and you can order it in many different switches and languages, including MX Silver and Nordic ISO.
« Reply #4 on: Sun, 20 August 2017, 15:17:11 »
Wait.. what!?! Why i haven't picked this up from anywhere?  Have to look into this! Thanks a lot, Lancelot!
