Author Topic: SA Blood/Shadow  (Read 8692 times)
Offline pixelpusher
SA Blood/Shadow
« on: Sat, 19 August 2017, 22:31:55 »
Offline scwoopz
Re: SA Blood/Shadow
« Reply #1 on: Sat, 19 August 2017, 23:00:19 »
Looks to be maxkeys
ortho or shmortho
Offline clickityClackity
Re: SA Blood/Shadow
« Reply #2 on: Sat, 19 August 2017, 23:00:50 »
Haven't heard of it, but the Meta button should definitely say Metal. And then obviously any time someone pressed Super + Metal, (fill in the blank).
Offline pixelpusher
Re: SA Blood/Shadow
« Reply #3 on: Sat, 19 August 2017, 23:30:26 »
Looks to be maxkeys
The translation says SP
Offline scwoopz
Re: SA Blood/Shadow
« Reply #4 on: Sat, 19 August 2017, 23:43:42 »
Looks to be maxkeys
Though render says Back Space.
Not really sure.
ortho or shmortho
Re: SA Blood/Shadow
« Reply #5 on: Sun, 20 August 2017, 00:25:23 »
It's a GB. The QQ channel for it is 633407901.
It's SP SA, just bad renders, check the color chip codes in the render. Chinese communities really only use TKL (as far as I've seen), so they don't put as much compatibility as we do in their sets.
It's a 50 set GB, my assumption is that they preordered a bit ago. Expected delivery is April 2018.
Offline pixelpusher
Re: SA Blood/Shadow
« Reply #6 on: Sun, 20 August 2017, 00:43:46 »
Thanks for the info, sir!
Offline Berzerker
Re: SA Blood/Shadow
« Reply #7 on: Sun, 20 August 2017, 22:08:06 »
Looks to be maxkeys
Not really sure.
Maxkeys has a standard set they give out which is about 140 keys, includes compatibility for layouts like 75% and 1800. This has none of that.
