Author Topic: Lubrication Syringe vs. Tube?  (Read 4265 times)
Offline FloFoer94
« on: Tue, 22 August 2017, 06:48:28 »
So i was looking at candykeys new offer for lubrication stuff (Here: https://www.candykeys.com/product-category/lubrication/)
Just wondering since i'm a noob at this: What is the advantage of lube in a syringe vs. a tube? What is more recommended?
I want to lube the stabilizers on my Magicforce 68, since i heard this is somewhat (partially) possible without desoldering the board.
« Last Edit: Tue, 22 August 2017, 06:57:57 by FloFoer94 »
Re: Lubrication Syringe vs. Tube?
« Reply #1 on: Tue, 22 August 2017, 16:59:14 »
I have had a tube of this for a few years and am finally at the bottom of it, I need to order a new one.
Great product and spectacularly easy to use.
https://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube
- D Trump 2026-10-24
Offline eksuen
  • Ambassador of explosions.
« Reply #2 on: Tue, 22 August 2017, 17:28:30 »
I just use a toothpick. I squeeze some onto the tip of a toothpick and apply where I want.
Offline jcoffin1981
« Reply #3 on: Tue, 22 August 2017, 19:49:05 »
You are using very minute amounts so the syringe is superior in my opinion.  The syringe allows more precise application, but what is better is to squeeze a small amount into a clean container and apply with toothpick.  Either way the syringe is probably better.
Offline cmc
« Reply #4 on: Tue, 22 August 2017, 19:55:11 »
For switches/guides, I've used a small paintbrush, which lets you apply a very thin layer of lube consistently.  But I used the syringe directly for the stabs.
