Author Topic: My first MK and suggestions for keycaps!  (Read 1832 times)
Offline Mardrik
« on: Tue, 22 August 2017, 11:40:57 »
Hi!
So, story short, I WAS thinking of building from scratch, but because of budget problems, decided to start with something cheaper.
I got this baby last week and until now, I must say the typing feels really great, I got it with Outemu Browns, it is the non-backlit version, so no dip switch on the back, which means no remapping of the Fn key :( (should have researched that before buying)
rest of imgs: http://imgur.com/a/VNDvj
Anyways, I'm looking to buy new keycaps for this beauty, I saw this Vortex and loved the DSA profile, so, went to Alixpress and found this kit, the thing is, it doesn't come with a Function key, not a big problem really, just wanted to check with you all if you are aware of other DSA options for me to consider.
Offline Mardrik
Re: My first MK and suggestions for keycaps!
« Reply #1 on: Tue, 22 August 2017, 11:43:56 »
Forgot to mention the model, in case you don't know, it is the White Silver Magicforce by Qisan, bought it on Amazon
Offline merlin64
    • MechMerlin
« Reply #2 on: Tue, 22 August 2017, 12:09:08 »
That's a great keyboard to have. If you're interested in DSA, check out what flashquark has to offer. They are US based so I hope that works for you.
Offline scwoopz
« Reply #3 on: Tue, 22 August 2017, 12:15:27 »
as Merlin said, check out flashquark. As well, you can just buy granite from pimpmykeyboard.com which is the set you're looking for, though it's going to be a bit more expensive because it's from the real DSA manufacturer (Signature Plastics) not a Chinese manufacturer.
FYI, you can edit your post so you don't need to add a new comment.
ortho or shmortho
