Author Topic: Reverse mount RGB LEDs  (Read 4924 times)
Offline mmca
« on: Wed, 23 August 2017, 00:58:22 »
Anyone know where I can get these sort of reverse mount RGB LEDs?
Seems the Vortex Race 3 comes with the LED drivers (MBIA043GP) already in place.
And in some of the early reviews they shipped out RGB versions.
This looks like something interesting to play with.   ;D
Offline pomk
Re: Reverse mount RGB LEDs
« Reply #1 on: Wed, 23 August 2017, 05:29:12 »
These are a bit expensive at over 30 cents per piece:
https://www.digikey.com/product-detail/en/qt-brightek-qtb/QBLP677R-RGB/1516-1282-1-ND/7567403
These are a lot cheaper, but make nowhere near as much light with the same current:
https://www.arrow.com/en/products/23-23br6ghbhc-a012a/everlight-electronics
The cheaper ones are also smaller and thus easier to make PCBs for.
There are others as well, but for some reason finding them is not that easy.
Offline mmca
« Reply #2 on: Wed, 23 August 2017, 12:20:17 »
It seems to be out of stock everywhere.  But thank you for the lead.
Offline ODBrown
« Reply #3 on: Wed, 06 September 2017, 22:46:16 »
First post (long time lurker):
This was the first thing I did to my Race 3 when I got it a few months ago. It took me a long time to figure out which leds to use.  The size is critical. I remember the 5050 (5.0mmx5.0mm leds are too big. The ones for this board are closer to 3x3. I'll find out and update. UPDATE: the 3528 is the right size. The DigeyKey link looks like the ones I bought. 2 points: 1) the reverse mount is important unless you want them to face down. 2) having flat leads is important. I bought the same thing except the leads were wrapped around the edge of the led. I destroyed all of my fingernails bending the leads out by hand and then flattening them with a hemostat. BTW - 100 of the ones I bought cost under $7 shipped to the USA. Let me know if you want the eBay link.
If you like RGB Leds, and you can solder, then this is a worthwhile mod for this board. This and the program-ability are  the reasons I bought the Race 3.
https://imgur.com/yG6DrFW
Also, The programming is already in the firmware on this board and is the same as for the Pok3r RGB. There are some good Youtube videos describing the color options and lighting patterns.
« Last Edit: Wed, 06 September 2017, 23:53:51 by ODBrown »
Vortex RACE 3 modded with RGB leds --- Pok3r w/ Blues --- FILCO Majestouch 2 Multicam & Blacks (doesn't get used much cuz I can't find it on my desk ;) --- Let's Split V2 --- 3 Model M Boards --- Multiple Cherry G86-63400 144 keys programmed for Autodesk and Adobe
