Advanced search
bounce or buckle?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
NEW USERS, READ
THIS!
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Keyboards
Shift keys working sporadically with HHKB build
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Shift keys working sporadically with HHKB build (Read 1888 times)
JunkFace
Thread Starter
on:
Thu, 24 August 2017, 13:30:50 »
I recently customized a HHKB with the Hasu bluetooth controller, some mx stems and 35g domes. I've probably took the pcb out 10 times now and for whatever reason the shift keys don't work consistently. I think the issue might be with the way the springs align with the capacitive part of the PCB since those keys aren't on the grid. I was thinking of either taping or gluing the domes directly to the pcb so I know they're aligned properly. My question is has anyone else had this problem and what ended up being the solution?
Logged
JunkFace
Thread Starter
Re: Shift keys working sporadically with HHKB build
Reply #1 on:
Sat, 26 August 2017, 17:29:25 »
Just had some time to tear this board apart and tape the domes in place. Worked like a charm I'm now functioning at 100%
Logged
Hordak
Reply #2 on:
Sun, 27 August 2017, 00:56:49 »
You might want to try it the reverse way, i.e. lay down the case with the top side facing the table, then place the domes and springs into the holes on top of the extended sliders and finally screw on the PCB.
Logged
ander
Esteemed Elder
I type, therefore I am
Reply #3 on:
Sun, 27 August 2017, 04:07:48 »
On the plus side, since you already have to hold down so many extra keys to do what we dinosaurs with full-size boards do with one finger, maybe you should just give yourself a break and let go of the whole Shift thing.
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Keyboards
