Author Topic: [IC] Treasure TYPE-9 : An Aluminum minimal Macropad (Series II coming soon)  (Read 69175 times)
Offline Treasure
  • Industrial Designer / Inventor / Maker
    • Design & Eng
9-KEY MACROPAD MINI KEYBOARD
CURRENT PRODUCTION STATUS
PRODUCTION DONE
You can get a macropad on macropad.co
Group Buy topic : https://geekhack.org/index.php?topic=96461.0
SOLD OUT
- PCB Assembly (DONE)
- Rubber pads (DONE)
- Preset Cards ( In PRODUCTION --> 05/08) (DONE)
- Auminum Case ( In PRODUCTION --> end of May) (DONE)
Hello to all,
I am an Industrial Designer currently designing a minimal 9-Key macropad
This kit is designed with the user in mind : Unibody, easy to use, to program, and solder.
Specifications :
  • Unibody CNC case Type 6061 "Aircraft Grade" aluminum
  • Pre-Assembled PCB with Microcontroller, nothing to solder
  • Satin sandblasted finish + Anodized color
  • PCB mount for Cherry MX keys
  • USB Type B connection
  • For use with the QMK Firmware builder
  • "Easy to use" firmware presets (For Ableton, Windows 10 ...) and associed mini card layout (Size of a business card)
Looks great with retro SA / DSA keys, works with every shape.
In the kit, you will find :
- The CNC aluminum case
- The assembled PCB & screws
- Two preset cards
- you provide MX Keycaps and keyswitches
PROTOTYPES :
A working PCB prototype and a case prototype has been made to evaluate size and shape.
The prototype was done with a Pro Micro. The final product will have a fully assembled SMD PCB.
CARDS
Each kit will contain cards with layouts for software shortcuts
And one blank side where you can write down your own layout.
Eric
« Last Edit: Sun, 28 April 2019, 12:09:33 by EricArts »
Offline Data
Re: [IC] CNC Aluminum 9-Key minimal Macropad
« Reply #1 on: Fri, 25 August 2017, 10:11:05 »
Neat.  :thumb:
This is very similar to projects done by RAMA in the last year or so.
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #2 on: Sat, 26 August 2017, 00:44:27 »
I would suggest that if you're going to go through the effort of designing a CNC'd 9keypad, at least go with fully SMD PCB. Not only does it itself look better, in volume they'll be most likely equal to or cheaper than a pro micro board, and you'll be able to lower your case profile due to the reduced height. Plus, USB Mini is a nicer keyboard connector than Micro.
Granted, my luck would be that's what you're planning and you just went with the pro micro board for prototyping :P
Offline Treasure
    • Design & Eng
« Reply #3 on: Sat, 26 August 2017, 02:38:24 »
Thanks Data  :thumb:
Hi Donucat, the final product will be a fully assembled SMD PCB with a atmega32u4, the pro-micro was only for prototyping purposes .
Offline bello2185
« Reply #4 on: Sat, 26 August 2017, 13:25:44 »
Looks very clean! I'd be up for a black anodized version of the slim one.  :)
Offline ChitownM2
« Reply #5 on: Sat, 26 August 2017, 14:45:16 »
Definitely interested. Red, grey, silver, & black would be my choices.
Do you have a ballpark price in mind? That would really be the deciding factor for me.
Offline PotatoTM
« Reply #6 on: Sat, 26 August 2017, 16:27:14 »
They look great, love the simplicity of type b!
Offline Scarhoof
« Reply #7 on: Sun, 27 August 2017, 14:49:14 »
Looks awesome! I like the A look better. More minimalist. Plus I would want black or space gray. Although the red looks really good too and I'm more likely to go with a crazy color for a small pad like this.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #8 on: Mon, 28 August 2017, 16:19:01 »
Case B is too similar to the Rama M4-A/M6-A, so my vote is for case style A!
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline Blazestorm
« Reply #9 on: Mon, 28 August 2017, 16:34:21 »
Is that really a bad thing? =)
I prefer B, something about it makes it stand out more. I'd take a couple of either style if they're reasonably priced.
Offline Treasure
    • Design & Eng
« Reply #10 on: Tue, 29 August 2017, 04:28:12 »
Hello to all and thanks for your comments.
  • I plan the price to be in the 49$ - 69$ range for the whole kit, depending of the quantity.
  • There will be 2 or 3 colors : A light one / A dark one / And another "special" one (bronze/red/gold ... )
Offline Auk
« Reply #11 on: Tue, 29 August 2017, 05:35:32 »
This sounds very promising   :thumb:
I prefer design b. Would the side bulges be hollow? or filled to give it some weight?
If the price is low, design a wouldn't be a deal breaker.
I disagree. A box with rounded ends is relatively simple and ubiquitous, the detail in the execution of the design will differentiate each product.
Offline ChitownM2
« Reply #12 on: Tue, 29 August 2017, 07:07:44 »
My preference would be design B as well.
At $49 I'd definitely be in.
Offline Scarhoof
« Reply #13 on: Tue, 29 August 2017, 11:10:44 »
    Ooh I like the bronze color idea! I hope we keep it sturdy and heavy if possible so it doesn't bounce around when used.
    Offline Treasure
      • Design & Eng
    « Reply #14 on: Wed, 30 August 2017, 04:26:19 »
    The side bulges will be filled. The case will be machined from an aluminum block
    I added a Google survey for type and color if you are interested : https://goo.gl/forms/O6u7JW13ZHr3xQby2
    Offline Auk
    « Reply #15 on: Wed, 30 August 2017, 07:46:26 »
    ...Google survey... https://goo.gl/forms/O6u7JW13ZHr3xQby2
    There are two options for blue? did you mean for one of those to be green, teal, cyan, orange, purple, pink, tan or something else?
    Offline Chromatrope
    • Tortures arrows, murders Lshift, doesn't press X
    Re: [IC] CNC Aluminum 9-Key minimal Macropad (UPDATE - Google form)
    « Reply #16 on: Wed, 30 August 2017, 14:31:35 »
    Red type B looks absolutely gorgeous, and I am in need of a livesplit macropad...
    I dance significantly better through bullet patterns than the alphanumerics. Known to cause heart failure in touch typists on sight.
    Offline Treasure
      • Design & Eng
    « Reply #17 on: Thu, 31 August 2017, 03:35:02 »
    Thanks, red is my favorite special color too
    Sorry, it was just a typo. The blue i intend is a bit tealish blue , like iPod mini / iPod touch blue.
    I added some color render in the form so you can have a better idea.
    « Last Edit: Thu, 31 August 2017, 03:41:49 by EricArts »
    Offline Calza
    « Reply #18 on: Thu, 31 August 2017, 05:23:45 »
    I missed out on the RAMA macropad so I'll definitely be in on this
    Offline olieatstofu
    « Reply #19 on: Thu, 31 August 2017, 10:07:40 »
    looking forward to this one :o
    Offline Treasure
      • Design & Eng
    « Reply #20 on: Tue, 05 September 2017, 15:28:03 »
    [UPDATE - 09/05/17] Hi to all !
    Concerning the survey, Black/Dark grey is now far ahead for the basic color; and Red is a little bit ahead for the "special" color. But i's not over.
    I am currently finishing the engineering & PCB design (Holes position)
    I will 3d print a case during next week to validate the PCB assembly & Order a few non assembled PCB's.
    Once this is ok, i will build the machined aluminum prototype.
    Offline Miotch92
    Re: [IC] CNC Aluminum 9-Key minimal Macropad (UPDATE - 05/09)
    « Reply #21 on: Sat, 09 September 2017, 02:42:08 »
    Love the look of that!
    Sent from my SM-G935T using Tapatalk
    Offline Treasure
      • Design & Eng
    « Reply #22 on: Tue, 28 November 2017, 06:45:17 »
    [UPDATE - 11/28/17] Hi to all !
    PCB and case design are FINISHED.
    You can see the PCB design right here. I am awaiting for the assembled PCBs
    PCB will be black in the final product.
    Regards
    Offline Treasure
      • Design & Eng
    Re: [IC] CNC Aluminum 9-Key minimal Macropad (UPDATE - 28/11)
    « Reply #23 on: Tue, 05 December 2017, 02:46:38 »
    [UPDATE - 12/05/17]
    PCB  : Hi !
    50 pcs assembled PCB have been ordered.
    There is a 20 days leadtime, so i am expecting to recieve them in the beginning of 2018.
    The PCB will comes pré-assembled, so you won't need to solder anything (except the keycaps of course)
    CASE : Aluminum case prototypes are in fabrication, i am expecting late december.
    Regards
    Offline olieatstofu
    « Reply #24 on: Wed, 06 December 2017, 09:17:47 »
    [UPDATE - 12/05/17]
    PCB  : Hi !
    Regards
    I am looking forward to making my order!
    Offline Treasure
      • Design & Eng
    « Reply #25 on: Fri, 08 December 2017, 02:25:06 »
    Great ! I will keep you informed then
    [UPDATE - 12/08/17]
    Plain board PCB is finished (50 pcs)
    Next step is PCB asssembly.
    Offline Treasure
      • Design & Eng
    Re: [IC] CNC Aluminum 9-Key minimal Macropad (UPDATE - 08/11)
    « Reply #26 on: Tue, 19 December 2017, 05:17:07 »
    [UPDATE - 12/19/17]
    Update : PCB assembly is finished !
    Offline Draic
    Re: [IC] CNC Aluminum 9-Key minimal Macropad (UPDATE - 19/12)
    « Reply #27 on: Tue, 19 December 2017, 08:22:48 »
    no USB-C :(
    Offline Koobaczech
    • Don't forget to smile :)
      • Pearlboards
    « Reply #28 on: Tue, 19 December 2017, 09:21:51 »
    Super cute, great work. I see 2 designs, an oval and a box. I'm all in for a box one :] GL
    Offline Treasure
      • Design & Eng
    Re: [IC] Macropad TYPE-9 : Aluminum minimal Macropad (UPDATE - 01/08)
    « Reply #29 on: Mon, 08 January 2018, 04:02:15 »
    [UPDATE - 08/01/2018]
    Hello to all;
    I recieved the case prototype and it is very good, great details and finish, solid aluminum body
    It is a cute little keyboard.
    The case protoype is in "Apple Red" color,
    I will post other pictures with Keycaps and a video ! Stay tuned
    ie : The name is now "Macropad TYPE-9"
    Offline Wetherbee
    Re: [IC] Macropad TYPE-9 : An Aluminum minimal Macropad (UPDATE - 01/08)
    « Reply #30 on: Mon, 08 January 2018, 09:14:49 »
    So, basically a copy of RAMA's design? Looks great in red.
    Offline MikeTheTiger
    « Reply #31 on: Mon, 08 January 2018, 09:45:12 »
    I'd be in for the version that doesn't copy Rama's design.  :rolleyes:
    "all the numbers or none of them cmon man" -Kokaloo
    Offline DALExSNAIL
    • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
    « Reply #32 on: Mon, 08 January 2018, 09:51:17 »
    Hello to all;
    Where'd you get that cable? :thinking:
    Offline Treasure
      • Design & Eng
    « Reply #33 on: Wed, 10 January 2018, 09:38:26 »
    Hi, I have to disagree,
    The oval rectangle shape has been used for decades in Apple (Jony Ive - Ipod Mini), Sony, Olivetti (Mario Bellini) products.
    And the execution is different even if a common shape is used (Unibody design, C2-Type continuity ...)
    It is more a common inspiration for minimalist products than a copy.
    Anyway the type A design (slim) has recieved more votes than the type B in the poll, so it will more likely be the A design !  :)
    Offline WHeisenberg
    « Reply #34 on: Wed, 10 January 2018, 14:32:23 »
    Well, colour me interested. Looks awesome!
    « Reply #35 on: Wed, 10 January 2018, 14:50:39 »
    Good. I think we just want to see something a little different. I'm all in for type A.
    « Last Edit: Fri, 09 February 2018, 16:55:14 by HoffmanMyster »
    Offline odd
    « Reply #36 on: Thu, 11 January 2018, 13:17:02 »
    Im def in for at least 2 if the price will be in the range you posted. Regardless of the price ill at least get 1.
    Offline hq
    « Reply #37 on: Tue, 16 January 2018, 04:33:51 »
    Looks awesome! I'm probably in for 1, depending on the price maybe 2.
    Do you have a rough ETA on the GB?
    Offline funnystunny
    • Software Engineering student
      • GitHub
    « Reply #38 on: Tue, 16 January 2018, 05:06:00 »
    Damn. I'll probably be in for 1 if the price range stays as said. Got some spare gateron blacks all sad in a drawer
    Enviado desde mi Aquaris X mediante Tapatalk
    Offline Starston3
    « Reply #39 on: Fri, 19 January 2018, 09:38:59 »
    I'd be in for one of the slims if the PCB supports holtites and there is a USB -C version.
    Offline hq
    « Reply #40 on: Thu, 01 February 2018, 06:38:19 »
    @op any news on the topic?
    Offline Treasure
      • Design & Eng
    « Reply #41 on: Thu, 01 February 2018, 13:08:28 »
    Hi, yes, i am building a website and a presentation.
    update very soon on http://macropad.co/
    Offline Paopawdecarabao
    « Reply #42 on: Thu, 01 February 2018, 13:28:22 »
    This looks good! Type B and type 9 looks the same? Either way looks fine to me. Matches CA66.
    Offline Treasure
      • Design & Eng
    « Reply #43 on: Tue, 20 February 2018, 13:02:44 »
    Offline funnystunny
      • GitHub
    Re: [IC] Macropad TYPE-9 : An Aluminum minimal Macropad (UPDATE - 02/20)
    « Reply #44 on: Tue, 20 February 2018, 14:25:15 »
    10/10 aesthetic
    Offline KaosJ
    « Reply #45 on: Tue, 20 February 2018, 14:36:53 »
    I like it!!! Something about the price?
    Offline Treasure
      • Design & Eng
    « Reply #46 on: Thu, 22 February 2018, 11:54:59 »
    Hi to all, i will inform the price as soon as i can. I must confirm the price with the case supplier first.
    First run will be 50 pcs.
    Quantities will be 20x Dark Grey, 20x Light Grey and 10x Red.
    Offline amnesia0287
    • Formerly Amnesia
    « Reply #47 on: Thu, 22 February 2018, 11:56:17 »
    Oooo. Red.
    Offline dr-slump
    « Reply #48 on: Thu, 22 February 2018, 16:02:02 »
    Nice. Just in time for a B-Day prez for myself   :D ;)
    Waiting for GMK Miami Dolch ISO . . .
    Looking for: Titainium Spacebar 6.25
    Offline Starston3
    « Reply #49 on: Sat, 07 April 2018, 15:56:51 »
    Any updates on this? I still believe it should have USB-C but am definitely interested in getting one.
