Author Topic: HHKB Pro 2 unresponsive after wake from sleep  (Read 3160 times)
Offline Erikdayo
« on: Fri, 25 August 2017, 09:27:48 »
This has probably been covered before, but I had issues finding an immediate match in a Google search. This is my 2nd HHKB. I don't remember if my first one did the same thing. I think it probably did.
When I wake my computer from sleep, even if I wake it using the HHKB, I've noticed that when I start trying to type on the keyboard it doesn't become response until a few seconds later. This isn't even just immediate after wake up. If I wake up my PC and don't use the keyboard until 5 minutes later the HHKB is not responsive for a few seconds. Is this normal for the HHKB? Running Windows 10 Pro.
Just curious because I don't recall this issue with my FC660C, POK3R, and various other keyboards I've previously owned.
Re: HHKB Pro 2 unresponsive after wake from sleep
« Reply #1 on: Fri, 25 August 2017, 09:34:19 »
Try searching on google site:geekhack.org hhkb sleep you'll see some older threads but they probably won't help with windows 10 but might at least give you some ideas to try
Offline Erikdayo
« Reply #2 on: Fri, 25 August 2017, 09:39:32 »
Most stuff I looked at seemed related to Mac issues, but I found something to try after looking at general keyboard wake from sleep issues on Windows. Will have to try when I get home from work in 8 hours. Something about going to device manager, finding the keyboard driver, and unchecking "Allow the computer to turn off this device to save power". Might do the trick.
Offline scwoopz
« Reply #3 on: Fri, 25 August 2017, 10:20:00 »
There's a DIP switch for waking from sleep, but it doesn't work for me (Mac).
I click my mouse or unplug the replug the HHKB.
ortho or shmortho
Offline Erikdayo
« Reply #4 on: Fri, 25 August 2017, 10:53:49 »
That works to allow me wake the the computer with the HHKB. But it doesn't necessarily make the keyboard responsive after the PC wakes. Still sometimes doesn't respond for a few seconds. But I mentioned a fix above that might work for me. Not an option on Mac, unfortunately.
