Author Topic: How do I reduce the ping sound from the Apple m0110  (Read 3081 times)
Offline noot
« on: Thu, 31 August 2017, 04:14:08 »
Just fixed up my m0110 and noticed that the ping sound is very echoey.
I saw somewhere that you can put some sort of pad inside the housing to reduce the echo.
Any suggestions?
Offline pingmaster
Re: How do I reduce the ping sound from the Apple m0110
« Reply #1 on: Thu, 31 August 2017, 18:16:23 »
Earmuffs. Those are SKCC switches. Their green counterpart switches are called "pingmaster" switches due to their nature. You can dampen it a bit but it will still make that noise.
Offline orihalcon
« Reply #2 on: Thu, 31 August 2017, 18:52:29 »
Pretty sure it's due to the ringing of the springs within the switches.  I notice this with Green ALPs as well, and I found that lubing the springs pretty much completely took it away.  The lube just adds some mass and makes it harder for them to vibrate for very long. Problem is that I don't know if it is a good long term solution as you'd think eventually all of the lube would settle to the bottom of the spring due to gravity. You could also try to floss mod in theory too.  Never opened up one of the T mount alps before though, so not sure how feasible this all is.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Fri, 01 September 2017, 01:43:28 »
Ah, the King of Ping! Yes, these ping like hell and then some. It's due to the springs inside, as well as plate vibration, I think. If you muffle the plate with some filler material (cloth, foam, whatever) you can dampen it a bit, but SKCCs will ping at least a bit regardless.
Offline Wolf123rt
« Reply #4 on: Fri, 01 September 2017, 11:50:17 »
Reduce ping? Why would anyone do such a thing?
Offline noot
« Reply #5 on: Fri, 01 September 2017, 15:32:17 »
Huge fan of your videos! And I had read somewhere that a rubber pad that fits around the switches dampened the sound a tad.
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Fri, 01 September 2017, 19:10:13 »
Thank you :) . Yes, it will dampen it partially. But to be honest, give it some time. You might find it grows on you. It's part of the switch' character; something switches still had before the 2000s.
