Author Topic: Swapping switched on my Ducky Shine 2  (Read 1694 times)
Offline Daniel
« on: Fri, 01 September 2017, 09:38:53 »
Yo
I got some Gateron reds to replace my Cherry reds but I forgot that I have LEDs (white ones) in my keyboard that I will need to reinstall as well.
My question is which LEDs do I need to buy exactly? I'm assuming the resistors are built into the PCB, so I don't know what kind exactly I should purchase.
I would just reinstall the same ones that I'm taking out but I don't know how to hold them in place, unlike the switches that clip to the plate there's no way (that I know of) to hold them in place while I flip the board and solder their pins.
Thanks for any help..
Offline clee290
Re: Swapping switched on my Ducky Shine 2
« Reply #1 on: Fri, 01 September 2017, 09:56:08 »
Maybe you can try to use small alligator clips like these to hold the LEDs in place. It'll probably just be easier to get new LEDs though :P I think the general recommendation for LEDs are 1.8mm or 2x3x4. 3mm are possible, but I've heard they can have issues with some keycap profiles.
Offline Targa-TV
« Reply #2 on: Fri, 01 September 2017, 10:20:13 »
At 30:18 of this assembly:
t=612s
he takes a bit of sellotape to hold the leds in place.
Filco MJ2 Black - MX Red | VA88M - MX Brown | Cherry G80-3000 -
  MX Blue | Cherry G80-3000 - MX Black | XD75re - MX Silent Red
[image]http://i.imgur.com/our8YUc.png[/image]
« Reply #3 on: Fri, 01 September 2017, 10:30:48 »
Second using tape if you don't get new ones.
Offline Daniel
« Reply #4 on: Fri, 01 September 2017, 12:25:47 »
Awesome.  :p
I'll give that a go.
Thanks.
