Author Topic: O-Rings for Unicomp Ultra Classic?  (Read 2205 times)
Offline TallOne123
« on: Sat, 02 September 2017, 13:18:07 »
Greetings GeekHack,
I made the jump to Unicomp's Ultra Classic buckling spring keyboard after my Logitech g710+ w/ MX browns broke down. I was a bit disillusioned as to how LOUD this thing was so I went to Reddit and found out about "Floss Modding", but I'm wondering if I can take a step further and apply O-Rings to my keyboard. Google didn't turn up anything about buckling spring o-rings, so I thought the folks here might know of an alternative or two.
Ideally, I'd want some way to preserve the tactile experience while dampening on purely the sound.
Thank you.
Offline klennkellon
  • I like bottoming out
Re: O-Rings for Unicomp Ultra Classic?
« Reply #1 on: Sat, 02 September 2017, 16:07:20 »
O-rings can't be installed BS unfortunately. However most of what you hear in BS is just the spring itself. The bottoming out and upstroke are actually a lot less clacky than on regular mechanical switches so it wouldn't do much anyway.
If you want a tactile and quiet switch you probably will want to take a look at Matias Quiet Click switches.
« Reply #2 on: Sat, 02 September 2017, 16:25:42 »
Floss modding has a large and positive effect on Model Fs but not so much on Ms.
- D Trump 2026-09-28
Offline 0100010
  • Not Sure
« Reply #3 on: Sun, 03 September 2017, 10:24:58 »
I seem to recall someone posting a picture of an old Wheelwriter that had 1/2" or 7/16" O-rings around some of the barrels a few years ago (as in, when they removed the caps, those O-rings had been in place for a long time).
Always meant to order some, just to check for affect on sound // never got around to it.  Now I am hunting for that old picture...
