Author Topic: melt's XT  (Read 7253 times)
Offline melt
    • check out my Instagram!
melt's XT
« on: Tue, 05 September 2017, 03:21:36 »
Thought I'd post some pictures of my XT.
Mods:
  • Raw brass feet
  • Pewter keycaps
  • RGB LED Mod for Caps/Num/Scroll Lock
  • Dvorak native with double backspace
  • Page up/down, home/end, insert/delete, and arrows on function cluster
  • 4 Pin Mini-XLR to USB with Litz braided cable
« Last Edit: Tue, 05 September 2017, 07:01:46 by melt »
Re: Melt's XT
« Reply #1 on: Tue, 05 September 2017, 05:51:11 »
That cable is pretty sweet.
Did you make it yourself?
« Last Edit: Tue, 05 September 2017, 06:12:02 by SpAmRaY »
Offline melt
Re: Melt's XT
« Reply #2 on: Tue, 05 September 2017, 06:02:59 »
The cable was done by Pexon. The connectors I sourced.
Offline hayt
Re: melt's XT
« Reply #3 on: Tue, 05 September 2017, 11:11:04 »
This keyboard is so baller on so many levels  :thumb:
Offline JP
Re: melt's XT
« Reply #4 on: Thu, 07 September 2017, 19:04:01 »
I really do like that connector. I wanted something similar but had trouble sourcing what I had envisioned. Was there a particular reason why you mounted the connector on the top as opposed to the back or sides?
About Me | The Collection
Offline Giorgio
Re: melt's XT
« Reply #5 on: Fri, 08 September 2017, 04:31:40 »
Where did you find all these original caps? The white ones are from a typewriter, but the others? thanks
