Author Topic: Shiny blank ISO keycaps with Cherry profile  (Read 5098 times)
Offline panzermuffin
« on: Thu, 07 September 2017, 07:47:10 »
Hey geekhack!
Im currently searching for a keycap set that has the following parameters:
- Blank
- ISO(-DE) compatible
- Cherry profile
- Shiny. Im currently on a SA1976 keycap set and love the shine and feel of it.
Colour is debatable. Black would be great, but also white whit grey or other colours for accents.
Does something like this exist?
Offline sysfury
Re: Shiny blank ISO keycaps with Cherry profile
« Reply #1 on: Fri, 08 September 2017, 07:22:56 »
« Reply #2 on: Fri, 08 September 2017, 08:14:17 »
There aren't really any Cherry profile keycaps that are shiny. I think the ones with the finest grain would be the ones on Cherry's own keyboards and often some keys are incompatible with mainstream keyboards. Cherry made blank keys only as an OEM, to sell to other companies, such as Das Keyboard for a little while.
Cherry's are pretty smooth on the sides where as others have the grainy texture also on the sides.
PBT and ABS do have different feels also, PBT having somewhat less friction IMO and I think the grain is needed to compensate.
But... for blank ISO key sets in Cherry profile that will fit most keyboards, Gateron's is the only ready option AFAIK.
On a tenkeyless, I got a navy blue blank Leopold ANSI set on eBay. It had a spare Fn key that I could use as the left Shift and I got < and # (equivalent) from the numeric keypad's keys. That left only the Enter key: I dyed a printed Cherry Enter key with RIT Royal Blue.
And of course, keycaps will get shinier with use. ABS will get shinier faster than PBT.
« Last Edit: Fri, 08 September 2017, 08:18:12 by Findecanor »
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Thu, 14 September 2017, 04:56:26 »
Cherry POM caps exist as blanks and have a very smooth surface, not shiny though.
« Reply #4 on: Thu, 14 September 2017, 09:41:18 »
Yeah, but while shiny ABS has good friction against your fingertips, POM feels very slippery. The friction of PBT is somewhere in-between.
Offline davkol
« Reply #5 on: Thu, 14 September 2017, 09:51:55 »
No idea where you're getting this. Shiny ABS _is_ smooth, but _wet_ fingertips stick to it better… with dry fingertips, it's an entirely different story.
Offline Giorgio
« Reply #6 on: Thu, 14 September 2017, 10:11:47 »
There's an interest check for gmk blanks... If you have enough patience...  :thumb:
And if you type enough, they become shiny. Since there are no legends, you can also obtain uniform shiny by moving keycaps between most used and less used positions :-D
« Last Edit: Thu, 14 September 2017, 10:13:37 by Giorgio »
