Author Topic: Phantom ROW 0 stopped working  (Read 1733 times)
Offline jaux
« on: Fri, 08 September 2017, 12:04:05 »
Hi folks, I have built a custom keyboard with phantom + teensy a few days ago, it had worked fine until this morning when I was trying to switch to another case. Suddenly all the keys on ROW 0 (space, ctrl, alt, left, down, right...) stopped working, all other keys on the keyboard are still good.
My knowledge of electronics is quite limited, can anyone teach me how to check the connectivity between ROW 0 and teensy?
Thanks in advance!
Offline 0100010
  • Not Sure
Re: Phantom ROW 0 stopped working
« Reply #1 on: Sun, 10 September 2017, 21:04:34 »
Have a multimeter?  Typically you'd want to put it on ohm mode, and connect one lead to the row 0 pin on the teensy, and then the other lead to each row 0 switch pin to check for continuity.
« Reply #2 on: Sun, 10 September 2017, 21:26:36 »
Is the new case metal? It's possible it could have shorted out on the case.
Offline jaux
« Reply #3 on: Mon, 11 September 2017, 09:54:06 »
Thanks folks, I actually fixed the problem short after I posted here. The problem was I did a bad job on soldering pin B0 of teensy to phantom, it became loose after a few moving around and case changes. Luckily for me, after I applied a little bit solder to the pin, ROW 0 went back in service :D
