Author Topic: Kailh Pocket RGB Mechanical Numpad in stock on sale $88  (Read 54606 times)
Offline Bella_Hwang
  • * Moderator
    • www.kailhswitch.com
« on: Fri, 08 September 2017, 21:20:59 »
red /white/brown switch inside
Whether you’re entering data, doing calculations, or frequently using the number keys, having a dedicated numpad is really handy. Kailh outfits it with Kaihua’s new Box switches. Just like before, it allows you to program the lighting to breathe, cycle through colors and waves, and more. The switches, however, are IP56 rated to keep dust and moisture out. Created with a box around the cross stem instead of the cross stem just sticking up, they’re built to avoid corrosion and debris buildup. Plus, thanks to N-key rollover, no matter how many keys you press, the numpad will register them all. You can even use the numpad for calculations with the built-in calculator function, and program macros.
Note: At checkout, choose between Blue (white colored), Brown, and Red Kaihua switches.
Numpad Specs
•   23 keys
•   Plastic case
•   Kaihua Box switches (IP56 waterproof)
•   Colorful RGB LEDs
•   Doubleshot PBT keycaps
•   N-key rollover
•   Calculator feature
•   R5 profile keycap
•   LCD Backlighting panel
•   USB N-Key Rollover
•   Dual-layer PCB
•   Battery not included
•   Dimensions: 6.4 x 3.7 x 1.6 in (16.2 x 9.5 x 4.1 cm)
•   Weight:280 g
•   Made in Taiwan
kailh Box Blue (white colored)
•   Dust- and moisture-resistant
•   Clicky
•   Operating force: 50 gf (+/-10 gf)
•   Tactile force: 55 gf (+/-10 gf)
•   Pretravel: 1.8 mm (+/- 0.3 mm)
•   Pressure point: 1.7 mm
•   Total travel: 3.6 mm (+/- 0.3 mm)
•   Reset point: 1.8 mm
kailh Box Brown
•   Tactile
•   Tactile force: 60gf (+/-10 gf)
•   Pressure point: 0.6 mm
•   Total travel: 3.6mm (+/- 0.3 mm)
kailh Box Red
•   Linear
•   Operating force: 45 gf (+/-10 gf)
« Last Edit: Mon, 11 September 2017, 21:03:17 by Bella_Hwang »
Dongguan City Kaihua Electronics Co,Ltd
http://www.kailhswitch.com
http://www.kailh.com
Email:sales12@kailh.com
