Author Topic: Where to Buy Alps SKCC Keycaps & Alternatives  (Read 3875 times)
Offline willmurray461
« on: Sat, 09 September 2017, 15:11:46 »
Does anyone know if it is possible to buy any alps skcc keycaps anywhere? Are there any other alternatives that will fit too?
Offline Weltschmerz
Re: Where to Buy Alps SKCC Keycaps & Alternatives
« Reply #1 on: Thu, 21 September 2017, 20:07:04 »
I mean afaik the only other source of SKCC keycaps are other SKCC keyboards, and even then, the switches can be mounted in a different orientation, so your keycaps would be turned 90 degrees. This is just from my limited knowledge though.
