Author Topic: Cospad (GHPad) flash/burn keymap problem with tkg.io  (Read 4169 times)
Offline bendim
    • Maker-Tutorials
« on: Sun, 10 September 2017, 11:46:13 »
Hello,
i bought a Cospad from here Aliexpress.
The board was working.
Now the bottom led are not working and the keys does not changed.
Any idea what i did wrong?
Planck Hand Wired
Offline bendim
    • Maker-Tutorials
Re: Cospad (GHPad) flash/burn keymap problem with tkg.io
« Reply #1 on: Sun, 10 September 2017, 12:04:18 »
I tried the standard layout http://www.keyboard-layout-editor.com/#/gists/6d51723fcdde92373079aa8786d7386e
and flashed the firmware and eep file with the tkg-toolkit from here https://github.com/kairyu/tkg-toolkit on mac, but same problem.
Planck Hand Wired
Offline DonutiKilla
« Reply #2 on: Sat, 07 October 2017, 02:59:07 »
Did you figure out a solution to flashing the cospad? I'm having the same problem.
Offline lovestream1989
« Reply #3 on: Tue, 10 October 2017, 13:03:28 »
Pls choose kai.tkg.io, don't us tkg.io, if using the latter, you may have problems like it:)
