Author Topic: [IC] CKL TKL  (Read 9456 times)
Offline clasicks
  • Formerly KeyboardUser4
[IC] CKL TKL
« on: Sun, 10 September 2017, 14:42:27 »
A few folks and I have been lazily talking about getting something together that combines two things we like. The HHKB layout mashed into a TKL design.
I have a lead on someone who may be interested in designing something like this, but I wondered if there was a substantial amount of people interested in it.
Right now, pure pipe dream - just looking for anyone with concrete interest. Please comment with thoughts.
KLE is attached.
Updated with proper proposed bottom row
« Last Edit: Sun, 10 September 2017, 15:51:25 by clasicks »
Offline xondat
  • i'm not a star
Re: [IC] CKL TKL
« Reply #1 on: Sun, 10 September 2017, 14:44:23 »
CKL TKL is the best name ever, so yeah, sure.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: [IC] CKL TKL
« Reply #2 on: Sun, 10 September 2017, 14:45:50 »
If this does not happen, there will be consequences.
Offline Firebolt1914
  • POM Overlord
Re: [IC] CKL TKL
« Reply #3 on: Sun, 10 September 2017, 14:54:57 »
literally modern amiga board unusable 0/10
Offline TalkingTree
    • My projects
Re: [IC] CKL TKL
« Reply #4 on: Sun, 10 September 2017, 15:13:19 »
Designing a plate you mean? You can use any TKL PCB and cover the Control keys.
Offline Kafka
  • i like clean things
Re: [IC] CKL TKL
« Reply #5 on: Sun, 10 September 2017, 15:21:50 »
I'm assuming designing the case with blockers.
Offline fouras
Re: [IC] CKL TKL
« Reply #6 on: Sun, 10 September 2017, 15:22:25 »
Might be blasphemy, but how about removing the normal escape key?
Offline clasicks
Re: [IC] CKL TKL
« Reply #7 on: Sun, 10 September 2017, 15:25:55 »
Not just a plate. but a full case milled with blockers in this layout. Aluminim, CNCed, Annoed - 2 parts. Weight, sure why not.
Offline clasicks
Re: [IC] CKL TKL
« Reply #8 on: Sun, 10 September 2017, 15:28:07 »
When diving into blasphemy might as well explore all options. I like your idea - i think the gap between the f keys are a little large for my taste - that and esc usage is habitual in the top left.
I did not know what to put there hence my L1 on the typical 60% esc
Re: [IC] CKL TKL
« Reply #9 on: Sun, 10 September 2017, 15:31:21 »
The Space Bar is 6u on the HHKB. It is just the 1.5-1-1.5 - 6 - 1.5-1-1-1.5 bottom-row layout that the Realforce keyboards have but without the keys on the sides.
That layout should be supported by several existing keyboards.  For instance, the Phantom PCB supports it with a 6u space bar - it even supports Fouras' layout above.
However, it would be nice to have an updated Phantom design with the controller on the PCB (which would increase compatibility with third-party cases) and support for PCB-mounted switches.
« Last Edit: Sun, 10 September 2017, 15:35:24 by Findecanor »
Offline clasicks
Re: [IC] CKL TKL
« Reply #10 on: Sun, 10 September 2017, 15:34:12 »
That layout should be supported by several existing keyboards.  For instance, it and layouts with one continuous line of function keys are supported by the Phantom PCB.
Yes many PCB's support this layout. Would make it easy to bring costs down if its only a case+plate design+manu.
I tend to stick with 7u for mx hhkb's - easier for GMK compability.
Re: [IC] CKL TKL
« Reply #11 on: Sun, 10 September 2017, 15:42:14 »
Ah. Now I see that you have 1.25u Alt keys, instead of the regular 1.5u keys that otherwise go with 7u space.
The 6u-space bar layout is nicer if you are used to a 6.25u space layout and use the right Alt key as it then is in the same space on both. In European layouts the right Alt is Alt Graph - with a different meaning, used for accessing third and fourth layers of symbols.
Offline clasicks
Re: [IC] CKL TKL
« Reply #12 on: Sun, 10 September 2017, 15:45:30 »
oh damn good catch, they are supposed to be 1-1.5-7-1.5-1 - will update the layout
Offline Kafka
Re: [IC] CKL TKL
« Reply #13 on: Sun, 10 September 2017, 20:42:03 »
I love hhkb layout, but this looks kinda goofy ¯\_(ツ)_/¯
Offline clasicks
Re: [IC] CKL TKL
« Reply #14 on: Tue, 12 September 2017, 15:48:46 »
Gonna close this up tonight over lack of interest, was worth a shot!
Cheers!
Offline afrokobe
Re: [IC] CKL TKL
« Reply #15 on: Tue, 24 October 2017, 15:22:42 »
might be thinking of being interested sometime in the near future
Re: [IC] CKL TKL
« Reply #16 on: Tue, 24 October 2017, 15:32:36 »
hhkb layout is fine
this is weird af tho
Offline clasicks
Re: [IC] CKL TKL
« Reply #17 on: Tue, 24 October 2017, 15:40:54 »
RIP. Yeah i had meant to close this
Re: [IC] CKL TKL
« Reply #18 on: Tue, 24 October 2017, 15:52:48 »
lock button is on the bottom left
Offline afrokobe
Re: [IC] CKL TKL
« Reply #19 on: Tue, 24 October 2017, 15:59:20 »
close ur mam
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: [IC] CKL TKL
« Reply #20 on: Tue, 24 October 2017, 16:00:56 »
Do not close this, this is the best layout ever made.
Offline afrokobe
Re: [IC] CKL TKL
« Reply #21 on: Tue, 24 October 2017, 16:56:29 »
dont ever give up on your dreams. CKTKL
Offline clasicks
Re: [IC] CKL TKL
« Reply #22 on: Tue, 24 October 2017, 16:57:08 »
CKL TKL PLZ
  • POM Overlord
Re: [IC] CKL TKL
« Reply #23 on: Fri, 05 January 2018, 14:14:48 »
Offline afrokobe
Re: [IC] CKL TKL
« Reply #24 on: Fri, 05 January 2018, 14:16:54 »
FIRE TKL WHEN NO MORE OF THIS
Offline mkarlsson
Re: [IC] CKL TKL
« Reply #25 on: Fri, 05 January 2018, 15:27:32 »
I like it
Enviado desde mi iPhone utilizando Tapatalk
