Author Topic: Hey, I'm looking for a pretty specific keyboard.  (Read 3090 times)
Offline lexlazootin
« on: Mon, 11 September 2017, 13:10:20 »
I'm looking for a keyboard with Cherry Silvers or like with a layout that has the main part with a numpad, Like without the middle part with the arrow keys. I'm not sure what that layout is called, like a Quick Fire TK.
I want to use it for high precision gaming, as corny as that sounds i would prefer if it has a 1000hz polling rate with little to no debounce.
I've checked and i haven't really found any specifically what i want and i can't find pretty much anything on the debounce timings on any keyboard. i would even pay for a custom if it meant i could guarantee low latency.
Thanks ;)
Re: Hey, I'm looking for a pretty specific keyboard.
« Reply #1 on: Mon, 11 September 2017, 13:42:34 »
Something similar to a Redscarf III or TX-CP (that has arrows) , or maybe the welfare 96 key keyboards?
Offline Kavik
« Reply #2 on: Mon, 11 September 2017, 14:28:10 »
I'm not sure if there's a production keyboard (or even custom) that's exactly what you're looking for.
Your best bet is probably to buy a CM Masterkeys Pro M, a bag of MX Speed Silvers, desolder the stock switches, and solder in the silvers.
The middle part you're referring to is called the nav cluster btw.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #3 on: Mon, 11 September 2017, 14:57:21 »
Hi, Looking for a pretty specific keyboard, I'm Dudesnail!
Offline raxander
« Reply #4 on: Thu, 14 September 2017, 21:42:21 »
Sadly you just missed the group buy for this sucker: https://mehkee.com/products/96kee?variant=47768389839.
Kavik's suggestion to desolder the CM Masterkeys Pro M is a good one, but desoldering can be tricky if you're not experienced with it.  Soldering is much easier.  Sometimes people will sell unbuilt kits for the Welfare96 or similar on /r/mechmarket, or you could try posting there that you want one.  Good luck!  If you don't want to do any soldering or assembly, there are people offering that as a service who post periodically on /r/mechmarket.
« Last Edit: Thu, 14 September 2017, 21:43:54 by raxander »
