Author Topic: Let's Split milled aluminum and brass plates  (Read 5478 times)
Offline woodkeys
  • Crafter of quality custom keyboards
    • WoodKeys.click
« on: Mon, 11 September 2017, 23:32:51 »
I thought I'd share something I've been working on. A while back I design some wood cases for the Let's Split, and I have built several of those over the past couple of months. I recently met another community member on Reddit that was able to do waterjet cutting and CNC milling of aluminum. He took the files for my wood case and milled it from aluminum. Since the walls were designed for wood, they are thicker than a typical aluminum case and the end result is HEAVY!  Each half weighs over a pound. With the brass plates that he waterjet cut, the entire case weighs close to 3 lbs.
178182-0
178178-1
178180-2
Offline wolf
  • Ah, yeah, g'day.
Re: Let's Split milled aluminum and brass plates
« Reply #1 on: Tue, 12 September 2017, 23:05:50 »
That looks beautiful.  Mandatory disclaimer: I love yellow metals - brass, bronze, gold - so I'm probably biased.  Over 1.2kg - without the switches etc - is a significant mass.
Have keyboard, will travel...
Offline MatchstickMan
  • CAD Jockey - YOLO Enthusiast
« Reply #2 on: Wed, 13 September 2017, 12:54:17 »
That looks gorgeous!
I would love to see that brass plate on a dark wood. That might get me to buy a LS kit...
Current Projects:
- SouthPad -- Left-handed Numpad
- Full Split (Currently on hold)
Offline woodkeys
    • WoodKeys.click
« Reply #3 on: Wed, 13 September 2017, 14:26:16 »
Like this?
178272-0
Offline InvidiousIgnoramus
« Reply #4 on: Wed, 13 September 2017, 14:35:15 »
I long for the day when I find a beamspring. (At a not insane price)
Offline wolf
  • Ah, yeah, g'day.
« Reply #5 on: Wed, 13 September 2017, 23:01:37 »
Like this?
Now THAT is gorgeous.
<drool> Yes. Yes it is. </drool>
woodkeys, what key caps have you sorted for it?
« Last Edit: Wed, 13 September 2017, 23:23:29 by wolf »
Offline woodkeys
    • WoodKeys.click
« Reply #6 on: Wed, 13 September 2017, 23:04:39 »
Like this?
What key caps have you sorted for it?
Thanks. I'm not actually building this one. I built the case and had the plates cut. It's going out to a customer.
Offline wolf
  • Ah, yeah, g'day.
« Reply #7 on: Wed, 13 September 2017, 23:24:30 »
Well that's one bloody lucky customer.
« Reply #8 on: Thu, 14 September 2017, 12:43:21 »
Current Projects:
