Author Topic: IBM KB-3923 semi-clicky, are they good?  (Read 23219 times)
Offline EverythingIBM
« on: Sat, 13 March 2010, 23:00:55 »
These were out selling on ebay for quite awhile:
http://cgi.ebay.ca/IBM-VINTAGE-PS2-PS-2-BLACK-104-SEMI-CLICKY-KEYBOARD-NEW_W0QQitemZ350100070748QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item518397215c
I want to know what exactly they mean by "semi-clicky", and if these are worth getting. They're brand new, so, that's good.
I had my eye on them for awhile, and, want some advice if purchasing one. However, there's not much info of these on the internet.
Offline didjamatic
« Reply #1 on: Sat, 13 March 2010, 23:07:09 »
It's not clicky, it's a quality rubber dome though.
« Reply #2 on: Sat, 13 March 2010, 23:15:53 »
Quote from: didjamatic;163854
I just retired my Model M after using it for a week in favour of my trusty old KB-8923. I got 114 WPM on the Model M, and 94 WPM on the rubber dome; so not too much of a difference in typing performance.
I just wanted to know if those ones had something else. I may try buying it anyways because it looks pretty intriguing! It would match my other equipment being black (except my Creative SBS20s, but then I could use my T3030 instead).
Offline JBert
« Reply #3 on: Sun, 14 March 2010, 05:53:19 »
I'd also guess this is a black version of the white KB-8923 or vice versa.
They might be called "semi-clicky" because the key stems make a distinct sound when typing rapidly on it. Yet any keyboard of course has such sound, so the seller is probably trying to cash in on IBM's name and the "VINTAGE" marking.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline Specter_57
« Reply #4 on: Sun, 14 March 2010, 08:06:48 »
If this keyboard is available in both black and white versions...it would be interesting to get one of each...do some cap-swaps...and end up with a pair of interesting but "inverted" keyboards.
Spec57
Offline ch_123
« Reply #5 on: Sun, 14 March 2010, 08:28:09 »
Quote from: jbert;163880
i'd also guess this is a black version of the white kb-8923 or vice versa.
They might be called "semi-clicky" because the key stems make a distinct sound when typing rapidly on it. Yet any keyboard of course has such sound, so the seller is probably trying to cash in on ibm's name and the "vintage" marking.
HACKER STYLE!
Anyone notice that if you have an all-upper case post, the forum will automatically lower case it?
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #6 on: Sun, 14 March 2010, 12:46:28 »
Quote from: ch_123;163892
Yeah, someone stumbled over that a while back.
Offline JBert
« Reply #7 on: Sun, 14 March 2010, 14:34:30 »
HACKER STYLE!
Ehr... Yes?
The storage list:
[/SIZE]
Offline ch_123
« Reply #8 on: Sun, 14 March 2010, 14:59:31 »
You must have missed that guy who use to sell Model Ms, advertising them as "Hacker style" keyboards.
Offline pfink
« Reply #9 on: Sun, 14 March 2010, 15:13:21 »
Quote from: EverythingIBM;163853
I've got two of those, they're definitely rubber dome. "Semi-clicky" is probably the usually dopey eBay seller hype, as mine sound pretty much like any other rubber dome.
The keys on these are similar to the ones on the HHKB Lite 2, same rectangular stem shape although the keytops are angled somewhat differently. They're pretty decent rubber dome boards, IMO, although not worth $20+shipping.
« Reply #10 on: Sun, 14 March 2010, 15:31:39 »
Quote from: pfink;163977
Ah, so they're just like the ones I'm using but black.
I think the price is worth it; these old IBM rubber domes are my favourite keyboards (for other reasons than being a mere rubber dome). I'm just wondering if the black version has the amazing labels like the "ivory" ones. Only one way to find out! Buy it and use it for 10 years. Plus they're brand new; you can't exactly buy those things new anymore.
I never used a HHKB: I don't think those even existed back then!
The key stems for these IBM rubber domes SHOULD be square with two little arms on each side.
EDIT: and yeah, I wouldn't exactly call these VINTAGE, they're not that old (if they're vintage, then I am too; which I'm not).
Quote from: Specter_57;163889
Yes it is.
« Last Edit: Sun, 14 March 2010, 15:34:26 by EverythingIBM »
Offline pfink
« Reply #11 on: Sun, 14 March 2010, 20:25:38 »
Quote from: EverythingIBM;163979
According to this Wikipedia article the original HHKB debuted in 1996:
http://en.wikipedia.org/wiki/Happy_Hacking_Keyboard
I didn't realize they'd been around that long either.
Offline ch_123
« Reply #12 on: Sun, 14 March 2010, 20:32:12 »
But LOLOMG, they weren't made by IBM in America!
Offline nowsharing
  • Swoop
« Reply #13 on: Sun, 14 March 2010, 20:37:10 »
A Scarry Garcia reference!
« Reply #14 on: Sun, 14 March 2010, 23:59:42 »
Quote from: ripster;164064
Looks pretty much like any Logitech rubber dome.  Nice logo though.
These are OEM'd from Chicony.  The KB-8923.
Ah, so there IS a difference between the rubber domes on those. I still kind of want to buy one and test it out (later though I guess; I'll have some fun with it -- and yeah, I like the logo on that one; I'll pull an "Appleite" and buy it for aesthetics).
EDIT: Well, maybe I misread that. I'll just buy the darn thing and post a review.
I like the KB-8923 chicony OEM'd. The only quirk with it, is that the indicator lights are always dimly lit (they only glow more vehemently when activated). But other than that, these keyboards are really great! Seriously. I'm using it right now. Although, I may eventually go back on my model m. But I'm used to the keys on this, it's like part of my hand.
Quote from: webwit;164065
The KB-8923 keyboards aren't THAT bad. Although, I'm wondering what the difference of KB-6363 is.
Quote from: pfink;164057
Well, IBM would have had some keyboards out by then :p, especially the chicony ones.
« Last Edit: Mon, 15 March 2010, 00:06:49 by EverythingIBM »
« Reply #15 on: Mon, 15 March 2010, 00:14:35 »
Quote from: ch_123;164060
Well, the labels haven't worn off! :p
Offline JBert
« Reply #16 on: Tue, 16 March 2010, 16:19:01 »
I stand corrected.
Still rather solid keyboard though. Even if it ain't fit for typing, it can still double as a club when you want to keep your heavyweight NIB model F in pristine condition.
The storage list:
[/SIZE]
« Reply #17 on: Tue, 16 March 2010, 17:31:36 »
Quote from: JBert;164556
I stand corrected.
It's VERY solid. There's aboslutely nothing wrong with them. Ripster is just scared of IBM rubber domes.
As for keeping Model Fs in good condition -- they'll outlive you. I'm going to enjoy my IBM stuff and use it like it was meant to be used. I currently am enjoying my 8923, which, doesn't want to give out (the labels on these are better than the Model Fs, which, after awhile the dye fades).
« Reply #18 on: Tue, 16 March 2010, 22:09:59 »
Quote from: ripster;164670
I'm not scared of Rubber Domes.
It's Chiconys I'm scared of.
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">[/youtube]
IBM told Chicony to make the KB-8923 (I'm wondering if they told them how to design it too; it seems very IBMish), it's a perfectly able IBM product. Call me a heretic, but I prefer it over my Model M. YES! I'm leaving that 1986 Model M IN MY CLOSET FOREVER! Until someone pays me $200 for it (hey! I had to order that 10 foot SDL to PS/2 cord from brian for $30). Although, I'd REALLY love an industral model M with the BLACK square logo, now that is cool. I probably still wouldn't use it; I like my KB-8923 too much. If everyone used a KB-8923, the world would be a better place, and rubber domes would no longer be mocked.
Offline Pylon
« Reply #19 on: Tue, 15 February 2011, 15:47:26 »
I'm at the library and I'm typing on a Compaq version of the KB-3923. White, decent key feel (though the other KB-3923 next to me is really mushy). There was also apparently a WYSE version.
Chicony probably sold out the design to a number of companies.
