Author Topic: GMK BLANK CHECK  (Read 68278 times)
Offline xondat
  • i'm not a star
Re: GMK BLANK - QUOTE SUBMITTED - NEED A COOL NAME
« Reply #100 on: Fri, 22 September 2017, 14:34:46 »
complete 0-5 action
now we're talking
Offline TalkingTree
    • My projects
« Reply #101 on: Fri, 22 September 2017, 14:35:53 »
why not use R0 for F-row?
Indeed. R0 would be great.
fixing the 2 1u cap colors and going to request r0 for F row for complete 0-5 action.
Awesome!
« Reply #102 on: Fri, 22 September 2017, 14:55:39 »
but can you do it in a color that i can't already buy pls
maybe in red
thanks
Offline Giorgio
« Reply #103 on: Fri, 22 September 2017, 16:32:17 »
Why aren't the 2 R1 1U keycaps the same color as alphas?
This!
Also, why not use R0 for F-row?
Are you using RO on f row?
Offline xondat
  • i'm not a star
« Reply #104 on: Fri, 22 September 2017, 16:38:41 »
This!
Yes.
« Reply #105 on: Fri, 22 September 2017, 17:36:55 »
i gotta say even if it does run in 9009 colors i might still get it for that sweet 0-5 action
Offline clasicks
  • Formerly KeyboardUser4
« Reply #106 on: Fri, 22 September 2017, 18:19:34 »
mebbe we call it GMK Full Figure then
Offline mintyfruits
« Reply #107 on: Fri, 22 September 2017, 18:55:50 »
GMK Full Frontal
(Haha no, that’s actually a Gundam reference...)
Offline mogo
« Reply #108 on: Fri, 22 September 2017, 20:15:25 »
Tabula Rasa means Blank Slate. GMK Rasa?
GMK Emptiness
GMK Barren
GMK Simple And Clean (some kingdom hearts reference for bonus hype)
Offline pr0ximity
« Reply #109 on: Fri, 22 September 2017, 21:37:13 »
GM ...k
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #110 on: Sat, 23 September 2017, 04:24:54 »
nvm
Offline TalkingTree
    • My projects
« Reply #111 on: Sat, 23 September 2017, 06:06:20 »
Why a cool name? It's a blank set made by GMK, what's wrong with GMK Blank? People care for the colour scheme, not really the name of the set.
Offline Giorgio
« Reply #112 on: Sat, 23 September 2017, 06:58:31 »
While we wait for the price, we keep ourselves occupied.
Since this set will have a light color similar to champagne, I suggest
GMK Blanc de Blancs
" If your high school French hasn’t failed you yet, you may already know that “blanc de blanc” and “blanc de noir” literally translates into “white from white” and “white from black.” Besides (probably) being a Yoko Ono poem, this is just a handy way to indicate the grapes used to make your Champagne."
https://vinepair.com/wine-blog/blancs-de-noirs-vs-blanc-de-blancs-explaining-the-difference/
Offline sth
  • 2 girls 1 cuprubber
« Reply #113 on: Sat, 23 September 2017, 15:16:28 »
OK So I am gonna submit the correction for row 0 and color correction on the 2 1u caps.
if we get R0 on the top row do we want enough extra blanks to fill out a top row on a 60% without color variation (from the accented f5-8) ?!
Offline xondat
  • i'm not a star
« Reply #114 on: Sat, 23 September 2017, 15:18:30 »
But then it's R02345 :'( Depends how cheap the set is imo.
Offline sth
« Reply #115 on: Sat, 23 September 2017, 15:38:31 »
the other issue is esc caps for 60%... do we add in enough r1 caps to cover that? little stuff like this is why we cant have r0 things more often
Offline Giorgio
« Reply #116 on: Sat, 23 September 2017, 15:39:54 »
Can't we have a set that has the same profile as all the others??
Offline xondat
  • i'm not a star
« Reply #117 on: Sat, 23 September 2017, 15:43:40 »
Just do a normal one, not the accents. Only one additional cap so...
Nah, R0 is a must.
Offline sth
« Reply #118 on: Sat, 23 September 2017, 15:46:53 »
Nah, R0 is a must.
so its 9009 for TKL/75 but not 60%? :(
Offline xondat
  • i'm not a star
« Reply #119 on: Sat, 23 September 2017, 15:48:23 »
Fineeeeee, I guess it's only 3 caps. Still don't know the pricing so go for it and then adjustments can be made.
Offline sth
« Reply #120 on: Sat, 23 September 2017, 15:58:52 »
im not too worried about r0 support on 60% but i added in a couple of extra esc keys for R1. sound good?
Offline sth
« Reply #121 on: Sat, 23 September 2017, 16:00:19 »
because we're entering brand new territory here. if this works we're setting the trend for GMK blank sets to come. and R0 is cool
Offline sth
« Reply #122 on: Sat, 23 September 2017, 16:01:45 »
« Reply #123 on: Sat, 23 September 2017, 16:03:39 »
Call it "boring as Halverson"
Offline sth
« Reply #124 on: Sat, 23 September 2017, 16:04:41 »
GMK Church
Offline mintyfruits
« Reply #125 on: Sat, 23 September 2017, 16:29:05 »
Offline TalkingTree
    • My projects
« Reply #126 on: Sat, 23 September 2017, 16:58:12 »
1.25u R5? That's new to me. Are you sure GMK has the tooling for that?
Offline sth
Re: GMK BLANK - PROFILE UPDATE – R0-R5 BAYBEEEEEEEE
« Reply #127 on: Sat, 23 September 2017, 17:03:58 »
if not then the ansi are cursed. but if so i'd rather everybody get sum
Offline nugglets
« Reply #128 on: Sat, 23 September 2017, 17:09:17 »
They put it in the original render they gave you, right? Pretty sure they would have said something if they didn't have tooling for that, but maybe not.
Offline xondat
  • i'm not a star
« Reply #129 on: Sat, 23 September 2017, 17:10:49 »
Reignites hype
« Reply #130 on: Sat, 23 September 2017, 17:23:10 »
« Reply #131 on: Sun, 24 September 2017, 00:19:03 »
put your faith in the shark
Offline Giorgio
« Reply #132 on: Sun, 24 September 2017, 01:47:09 »
Meh, I'll need to adapt to the profile, it's like going from cherry to OEM. Seems like an idea with no basis. You won't be able to mix this set with any existing set. Top row is different from usual, and the bottom row different too. You even had to add some keys for 60% compatibility, go figure.
I wonder why these sets always try to reinvent the wheel, losing track of the objective. Wouldn't it be simpler to take the 9009, remove the duplicates, and then ask GMK for a quote, and then working from there? I was the only one who gave you an approximate cost of the set, I don't know if you noticed it. We'll see.
« Last Edit: Sun, 24 September 2017, 04:21:21 by Giorgio »
Offline cicada
  • Formerly iamacicada
« Reply #133 on: Sun, 24 September 2017, 02:19:11 »
was hoping for cherry blossom pink
Offline Giorgio
« Reply #134 on: Sun, 24 September 2017, 02:52:06 »
[erased double post]
« Last Edit: Sun, 24 September 2017, 04:19:44 by Giorgio »
Offline FoC_Tow
  • Brokehlicious
« Reply #135 on: Sun, 24 September 2017, 03:59:57 »
Blankx look fire.
R0 and 5? I don't know man...
Offline pr0ximity
« Reply #136 on: Sun, 24 September 2017, 06:09:09 »
GMK blanks in R0-R5 kind of is the objective, I think.
Offline Giorgio
« Reply #137 on: Sun, 24 September 2017, 07:56:14 »
Of really, I thought that the first objective was to make a popular inexpensive blank set. Surely these aspects come before considerations about the profile.
Offline mintyfruits
« Reply #138 on: Sun, 24 September 2017, 10:39:15 »
To be fair, I don’t think sth ever set the objective to be an ‘inexpensive set’. And it seems most of the people in the thread have agreed on the profile. :b
Offline sth
« Reply #139 on: Sun, 24 September 2017, 13:55:04 »
no sir the first objective is GMK BLANK
second objective is R0 and R5
me too pal. maybe next time... MOQ for custom colors is 250 i think.
small update: GMK updated renders coming soon, should be able to post by tomorrow and then we can get a quote. :thumb:
« Reply #140 on: Sun, 24 September 2017, 14:13:32 »
Me too. I think if this goes well, sth should do another run in a weird color like red or pink, despite MOQ concerns
Offline sth
« Reply #141 on: Sun, 24 September 2017, 14:22:13 »
what about sth having to pack and ship 250 keyset concerns :(
i would love to get a custom cherry blossom in GMK though.
« Reply #142 on: Sun, 24 September 2017, 14:28:32 »
ask sherry to help
¯\_(ツ)_/¯
i'd buy the **** out of red or pink, i've been looking for a red cherry profile blank set for a while but i can't find a good one
i kinda want one for my mira
Offline sth
« Reply #143 on: Sun, 24 September 2017, 14:35:30 »
ask sherry to help
¯\_(ツ)_/¯
yeah i'd probably look into partnering with a vendor next time. someone with better intl connects too! i dont know enough people in asia or EU who would want to handle proxying, i dont think...
Offline Giorgio
« Reply #144 on: Mon, 25 September 2017, 01:09:09 »
One year ago I asked for a quotation for a blank gmk Alphas set, the price for the keys circled in red was 25 EUR (50 pieces). This could be eventually considered an add-on, since the MOQ is only 75.
179039-0
« Last Edit: Mon, 25 September 2017, 05:48:40 by Giorgio »
« Reply #145 on: Mon, 25 September 2017, 01:28:23 »
A long time ago I asked for a quotation for a blank gmk Alphas set, the price for the keys circled in red was 25 EUR (50 pieces). This could be eventually considered an add-on, since the MOQ is only 75.
i mean yeah it's all 1u caps, which don't take much QC effort
i still think it's worth running as a full set and waiting for GMK to give quotes that reflect their recently updated (read: increased) pricing structure
Offline Giorgio
« Reply #146 on: Tue, 26 September 2017, 02:49:53 »
I wonder why it always takes so long to receive quotations from GMK... I had to wait more then two weeks.
Offline sth
« Reply #147 on: Tue, 26 September 2017, 15:59:04 »
I got an updated render over the weekend but I was really busy at work. here's GMK Blank -CURRENT
Offline TalkingTree
    • My projects
Re: GMK BLANK - LATEST RENDERS AVAILABLE, PLEASE COME COMPLAIN NOW
« Reply #148 on: Tue, 26 September 2017, 16:16:23 »
Since we're asked to complain, why there's not windowed R0 for Scroll Lock?
Don't take this too seriously.
Offline xondat
  • i'm not a star
« Reply #149 on: Tue, 26 September 2017, 16:22:47 »
This is an annoyingly good point.
