Author Topic: Tell me about a Better MX Clear!  (Read 6595 times)
Offline Severe
  • HHKB Zealot
« on: Tue, 12 September 2017, 14:48:55 »
I've been through all the mainstream switches. MX blacks, reds, greens, blues, Topres of all weights and measures and I finally settled on LOVING the MX clears on my Pok3r and my Vortex Core (clears feel much better on the CORE than they do on the Pok3r. maybe because of the smaller board.
I'm now building a Planck and want the feel of the MX clear. I love the weight and am willing to even go heavier since I don't so much type as carpet bomb the keyboard.
BUT
I want more of a tactile feel than the Clears offer. If feels spongy. Not as much on the CORE and it does on the Pok3r, but that defined bump just isn't there.
In closing i want
HEAVY switch. minimum 80g
PROFOUND tactile bump
MX compatible stems since I own several thousand dollars worth of MX keycap sets
Whatcha got?
HHKB Pro 2 Black Lubed 55g
Logitech G502 (Gaming) Logitech MX Master 2 (Day to day)
Re: Tell me about a Better MX Clear!
« Reply #1 on: Tue, 12 September 2017, 14:51:22 »
Just an FYI going heavier with mx clear will actually give you a less tactile bump.
Offline Marvellion
« Reply #2 on: Tue, 12 September 2017, 15:03:03 »
Halo Clear and Halo True might be what you want but you will have to wait for a while
Offline Severe
  • HHKB Zealot
« Reply #3 on: Tue, 12 September 2017, 16:52:07 »
I know that's an unfortunate side effect of heavier switches which is why I'm reaching out to the community to find something I may not have heard of that will offer what im looking for
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #4 on: Tue, 12 September 2017, 17:41:17 »
Outemu Ice Purple with 80g springs!!
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #5 on: Tue, 12 September 2017, 22:03:39 »
+1  :thumb:
-Dana
« Reply #6 on: Tue, 12 September 2017, 22:47:02 »
bsun brown housing
mx black spring
mx clear stem
that's some good ****
Offline _haru
« Reply #7 on: Tue, 12 September 2017, 23:03:18 »
bsun brown housing
mx black spring
mx clear stem
Agreed.
Offline OfTheWild
« Reply #8 on: Wed, 13 September 2017, 12:33:48 »
I think people are going nuts with the mix 'n match MX switch setups now. To the detriment of quality. To each his own though. For tactile switches my favorites remain gateron browns with 67g springs.  :thumb:
-Dana
Offline pixelpusher
« Reply #9 on: Wed, 13 September 2017, 12:45:31 »
Tactile Gray seem like they might be just for you.  Never tried them personally.
78g zealios might be worth a try as well
Gateron greens are great, snappy and heavy, but clicky.
« Last Edit: Wed, 13 September 2017, 12:52:00 by reececonrad »
Offline Severe
  • HHKB Zealot
« Reply #10 on: Wed, 13 September 2017, 13:42:10 »
gonna try some Greys
Offline SpecTP
« Reply #11 on: Wed, 13 September 2017, 17:05:32 »
I've tried blacks but I've always gone back to clears. I love the heavy feedback. But after playing long sessions of games on MX blacks, I can really feel my fingers wanting to cramp up.
Offline PollandAkuma
« Reply #12 on: Wed, 13 September 2017, 21:53:30 »
I think bump also depends on keycaps used
Offline OfTheWild
« Reply #13 on: Thu, 14 September 2017, 00:21:01 »
How do you mean?
-Dana
Offline superpiya
« Reply #14 on: Thu, 14 September 2017, 01:23:00 »
How do you mean?
I believe what he meant was, with thick or heavier keycaps (SA profile?) you will feel less bump compared with thin ABS keycaps. But since OP owns several thousand dollars worth of MX keycaps, there's no chance that he is going to use thin ABS on his mx clears.
Offline Severe
  • HHKB Zealot
« Reply #15 on: Fri, 15 September 2017, 09:05:29 »
How do you mean?
damn right I won't  :thumb:
Offline ideus
  • Björkö.
« Reply #16 on: Fri, 15 September 2017, 10:02:37 »
You should try greens.
Offline pixelpusher
« Reply #17 on: Fri, 15 September 2017, 10:41:01 »
I love my Gateron greens.  Of course, there's no way I would use them as my daily driver, but they are fun.  I can't imagine anyone would every actually use heavier switches.
Offline ideus
  • Björkö.
« Reply #18 on: Fri, 15 September 2017, 10:45:23 »
In my own experience, that it is by definition, different form any of yours: Lighter to heavier, blacks, ergo-clears, blue-lights, ghetto-greens. Right now using the first two, at home and at work, respectively.
Offline natas206
  • * Commercial Vendor
« Reply #19 on: Fri, 15 September 2017, 12:27:54 »
For what it's worth, if OP or anyone else are thinking about the Gateron browns, which are a tactile low-force switch and sometimes compared to the MX clears, they are very scratchy imo and its very noticeable. I currently have them installed on one of my personal Advantage keyboards. But to be fair I've grown to love linear switches like the MX Reds.
Offline dante
« Reply #20 on: Fri, 15 September 2017, 12:29:23 »
Dell KB522 rubberdome is superior to MX Clears.
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #21 on: Fri, 15 September 2017, 12:36:26 »
Jailhouse blues are definitely up there for me, but depending on how you mod them they can still be a bit mushy. Though most of the time I go for clears out of convenience :P
